Need help on my oil lines for turbo
Old Feb 25, 2008 | 04:36 PM
steggun revned's Avatar
steggun revned steggun revned steggun revned steggun revned steggun revned steggun revned steggun revned steggun revned steggun revned steggun revned steggun revned
Default Need help on my oil lines for turbo
I have a D16y8 and I am installing a turbo kit for the first time and I need to know where to put my oil lines in I know mostly for the return line but where do I do the pressure line or w/e if someone could get me pics of it or just tell me how to that would be GREAT and thanks alot and if someone could post pics of there turbo set up on a D-series that would be nice thanks alot.
Old Feb 25, 2008 | 05:20 PM
thermal's Avatar
TurboPipingSystems
Default Re: Need help on my oil lines for turbo
You have to use a T fitting. Take off the oil pressure sensor and use screw the T fitting on there. The oil pressure is above the oil filter. It has a single wire on it.
Old Feb 25, 2008 | 05:21 PM
ok thanks man really appreciate it ALOT
Old Feb 25, 2008 | 05:37 PM
thermal's Avatar
TurboPipingSystems
No problem.... you can also use a sandwich adapter like this. This goes in where your oil filter is. Then the filter will be on top of it. Use one of the holes for an oil feed line then plug the other holes that you do not need. The advantage of this adapter plate is having to use "filtered" oil to lubricate your turbo.
Old Feb 25, 2008 | 06:01 PM
Ok thanks again will go buy this stuff tommorrow then install this wekend or next thanks again
Old Feb 25, 2008 | 06:54 PM
LifeMage's Avatar
LifeMage LifeMage LifeMage LifeMage LifeMage LifeMage LifeMage LifeMage LifeMage LifeMage LifeMage
yeah any other questions about that stuff thermal knows all his stuff.
Old Feb 26, 2008 | 02:40 AM
umm nope no more question will let yall know if i do thanks alot!!
Ultracoupe
Engine / Exhaust / Drivetrain
34
May 13, 2009 07:22 PM
O Rly?
Jan 4, 2008 07:02 PM
