need help locked keys in
Old Feb 18, 2009 | 05:27 PM
wtbcar1's Avatar
wtbcar1 has disabled reputation
Default need help locked keys in
How would I get a set of keys out of my 95 hatch. Manual locks. I know call a lock smith blah blah . But on the lock there is a rod that goes down to the side of the door. now to pop that lock you u have to go up or down on it ? Or is there an easier way ?
Old Feb 18, 2009 | 05:43 PM
Lord Humongous's Avatar
VaDriven Mayhem
Default Re: need help locked keys in
Brick meet window
Old Feb 18, 2009 | 05:53 PM
Joker.'s Avatar
HNIC
Joker. Joker. Joker. Joker. Joker. Joker. Joker. Joker. Joker. Joker. Joker.
Originally Posted by Lord Humongous
Brick meet window
x2. Pm. "spic" he can help you out.
Old Feb 18, 2009 | 05:57 PM
CivicRenModelX's Avatar
CRX
CivicRenModelX has disabled reputation
Get a piece of cardboard and a piece of string.
Old Feb 18, 2009 | 05:59 PM
Joker.'s Avatar
HNIC
2 paper clips and a piece of gum also.
Old Feb 18, 2009 | 06:04 PM
dave22's Avatar
throwbAcura
Shove a wedge between the seal and the window. With your head pressed against the window and a flashlight you should be able to see the lock through the crack. Like a plastic square with metal bars coming off each corner. Get at one of those bars (as close to the plastic as possible) with a hanger and push down/pull up until it unlocks.
Do this on the passenger side. If you do it on the driver side you'll need to pull the handle and hold it up the whole time.
Old Feb 19, 2009 | 04:53 AM
wtbcar1's Avatar
LOL Brick Meet window lmfao . I was going to at first . Okay I will try these . Thanks guys !
Old Feb 19, 2009 | 05:19 AM
nosediv3's Avatar
typesb4thinking
nosediv3 nosediv3 nosediv3 nosediv3 nosediv3 nosediv3 nosediv3 nosediv3 nosediv3 nosediv3 nosediv3
if none of those work you can try this...
use your fingers or a wedge to pry the top of the door open
insert clotheshanger
profit.
Old Feb 19, 2009 | 05:49 AM
jimihendrixbro's Avatar
jimihendrixbro is an unknown quantity at this point
Go to Advance Auto and buy a slim jim. Its a thin metal sheet that has a hooked notch on one end. You can use it to unlock your door. It has intructions on the back. It takes a little bit of practicing but you can do it. They're only about $9.
Old Feb 19, 2009 | 05:54 AM
ufctapout's Avatar
MARK IT ZERO
Or get someone with Triple A to call for you. Where are you located?
