need help with integra started bogging after shift
Old 08-21-2010, 01:43 AM
DRINK BEER AND FIGHT
BREWSKI's Avatar
BREWSKI BREWSKI BREWSKI BREWSKI BREWSKI BREWSKI BREWSKI BREWSKI BREWSKI BREWSKI BREWSKI
Default Re: need help with integra started bogging after shift
Originally Posted by Fabrik8
Have you checked the coil yet? I'm serious, that MSD coil might have failed. That's not an uncommon thing to happen. You thought I was joking, didn't you...?
i bought a brand new distributor and took out all that msd shit and still nothing.
BREWSKI is offline
Old 08-21-2010, 08:35 AM
oh sol slow
slowMR2's Avatar
slowMR2 is a jewel in the roughslowMR2 is a jewel in the roughslowMR2 is a jewel in the rough
Originally Posted by SCREECHO
check your timing.
agreed same thing happened to me, i got gas left the gas station and caught a light, when the light turned green i went of course shifted into second and the car shit on it self, it jumped one tooth of timing.
slowMR2 is offline
Old 08-21-2010, 08:36 AM
BREWSKI's Avatar
when you jump like that tho that usually means a new belt correct?
BREWSKI is offline
Old 08-21-2010, 08:43 AM
If the belt is worn enough that it is able to jump a tooth, it should definitely be replaced. Even if it isn't worn (and the problem is related to belt tension) it should be replaced after it jumps, because that causes local damage to the teeth. I can't say I've really been impressed with Honda timing belt tensioners though, there is too much room for error and things to go wrong.
Old 08-21-2010, 08:48 AM
oh sol slow
slowMR2's Avatar
yes deff replace with a new belt, and as fabrik8 said the timing belt tensioners are crap, and would replace that also while you are in there, dont forget the water pump also while you are in there
slowMR2 is offline
BREWSKI's Avatar
Alright sounds good.... is the belt hard to put back up and will i have to adjust the timing or what? im really big into DIY so if you could point in a good write up that be great im searching google now.
BREWSKI is offline
Old 08-21-2010, 08:52 AM
oh sol slow
slowMR2's Avatar
there are tons of DIY info on hondatech, and i wouldnt say its hard to do, more a pain in the ass.
slowMR2 is offline
Old 08-21-2010, 08:53 AM
BREWSKI's Avatar
i looked in the teggie section and i couldnt find one on timing ill look again.
BREWSKI is offline
Old 08-21-2010, 08:55 AM
oh sol slow
slowMR2's Avatar
http://www.c-speedracing.com/howto/timingbelt/tbelt.php
even has pics hope this helps bro
slowMR2 is offline
Old 08-21-2010, 09:02 AM
BREWSKI's Avatar
yeah appreciate it and thanks to everyone!
BREWSKI is offline
Quick Reply: need help with integra started bogging after shift
