need help with intake etc etc
Old Apr 17, 2007 | 04:32 PM
sive ick's Avatar
sive ick is an unknown quantity at this point
Default need help with intake etc etc
ok so i just got a pm6 and put it in my car after doing my mpfi swap not to long ago,and im only throwing a iac which isnt too bad just when its cold
but ok with the pm6 if i have wide open throttle,like fully,the car will bog down and feel like it has no throttle response at all,but if i take a slowly and floor it like3/4 it drives fine with no problems at all
any ideas what the problem could be
i have a pm5 map sensor which is my guess,but also maybe the ignition timing is off,or a possible vacum leak,but im clueless
like i said im only throwing code 14 no other ones at all
it didnt do this on a pr4 but it was dumping way to much gas so this is my only option,even if i get ran over trying to get on the interstate
Old Apr 18, 2007 | 02:46 AM
sive ick's Avatar
Default Re: need help with intake etc etc
Old Apr 18, 2007 | 02:47 AM
sive ick's Avatar
double post
Old Apr 18, 2007 | 05:34 AM
Hi Skuuu's Avatar
Hi Skuuu has disabled reputation
Duuuuuuuuuuuuude. The Dual point Throttle position sensor is your problem! I wish you woulda told me that before. You can't use that sensor!
Old Apr 18, 2007 | 09:55 AM
sive ick's Avatar
ummmmm nope it is a zc tps
the problem was on of the dual point plugs not sure the name but ya long story,fixeddddd
Old Apr 18, 2007 | 07:20 PM
Hi Skuuu's Avatar
word
Old Apr 18, 2007 | 08:58 PM
SlowLS's Avatar
Sumospeed #O.G.
Check your wiring and make sure nothing came loose. My car sis the same thing you are describing and it ended up being the wiring came loose at the ecu. Could also be your tps. try another throttle body.
Old Apr 19, 2007 | 02:55 AM
sive ick's Avatar
nothing was loose,just when i did my mpfi harness i cut off the electric aircontrol valve,instead of the purge control valve(dual point intake manifold)
so i just had to go back in and we wire it
so its fixed
John M
Want to Buy / Trade ARCHIVE
Jul 8, 2008 04:19 PM
jujub1
12
Jan 25, 2008 04:21 AM
