Need help Installing a headunit
do i need a power antenna for the head unit to work...i have a power antenna wire coming off of the head unit but not on the cars wiring harness...the previous owner cut the harness so i cant get an adapter...it looks like he ran it into a fuse?...is that possible?
Re: Need help Installing a headunit
The power antenna wire just makes the power antenna raise and lower. Does you car have a power antenna? If it doesn't, don't worry about it.
It might be better to get a friend to help you though...
ok thanks...theres a wire ran from the fuse box (a 30 fuse) to behind the head unit area...any idea what that might of been for?
