Need Help Diagnosing Problem
Old Oct 14, 2005 | 09:46 AM
jdm93civic's Avatar
jdm93civic is an unknown quantity at this point
Default Need Help Diagnosing Problem
Hello all I have recently starte to hear a humming noise coming from my drivers side tire in the front from what I have been told is that is more then likely the Wheel bearing, but I would if any one hear that is a mechanic that could take a look at it and maybe drive it around. Them Hmm is causing the car to feel very loose and it gets louder the faster I go. I did check the axels but i only see that the front 2 cv boots are torn open but that has been like that for while now. If any one could help me out i would appreciate and if you could fix it I could pay you. Thank You.
1993 honda civic Dx coupe
Old Oct 14, 2005 | 10:17 AM
EEK's Avatar
EEK
卐 Walnuts
Default Re: Need Help Diagnosing Problem
wheel bearing or bent rim
Old Oct 14, 2005 | 11:07 AM
HORNY4ZORNY's Avatar
takin it all
HORNY4ZORNY HORNY4ZORNY HORNY4ZORNY HORNY4ZORNY HORNY4ZORNY HORNY4ZORNY HORNY4ZORNY HORNY4ZORNY HORNY4ZORNY HORNY4ZORNY HORNY4ZORNY
any camber issues......i had major camber on the front wheels and i had the humming noise also and what was causing it was due to the camber it had worn out my tires so bad that the steel belts were humming.....but if its not that check the wheel bearings...jack up the car and make sure the tire is on the hub tight and wiggle it. if it moves then you have wheel bearing issues
Old Oct 14, 2005 | 02:11 PM
jdm93civic's Avatar
I see do you know what would be a good price for labor on that type of work? to replace a wheel bearing?
Old Oct 15, 2005 | 06:03 PM
DOHC crx VTEC's Avatar
DOHC crx VTEC is an unknown quantity at this point
My Cv axles boot was torn for a while...then it got dry cuase the boot holds the grease in to keep the axle greased.....It was making a noise...then i launched...and i spat the axle out...kinda sucked...made a crack in my fender:-/ .....It could be a variety of things...Just my thought.
Old Oct 16, 2005 | 08:26 AM
minboostS13's Avatar
midnight motorsports
minboostS13 has disabled reputation
sounds like a wheel bearing to me. How are your tires? Bubbles on the inside of the wheel? Shaking rattling? Braking problems? Good luck.
Old Oct 17, 2005 | 05:26 AM
Odin's Avatar
Suprize cockbag!
Odin has disabled reputation
im a mechanic - it does sound like your wheel bearings - just lift the car up with the wheel on tight and try moving it. If there if some movement then they are bad. Your local shop - idk how much they would charge but a dealership would charge you for parts and probably like 2 hours labor for each bearing you replace.
Old Oct 17, 2005 | 05:54 AM
sucio7's Avatar
import mechanic
sucio7 has disabled reputation
GO TO A SOLITAIRE STREET AND DRIVE TURN FROM ONE SIDE TO THE OTHER IF IT COMES AND GOES YES IS UR WHEEL BEARING
IF NOT PASS U HAND ON TOP OF UR TIRE IF IF FEEL BUMPY IS UR TIRE IS "FEATHER "
Old Oct 17, 2005 | 07:14 PM
jdm93civic's Avatar
does anyone know where i can get this work done. I dont have much time or money to waist as it is my daily driver i just want to get it fixed as soon as i can
Old Oct 18, 2005 | 04:26 AM
sk8rmike's Avatar
Bitches get Stitches
You're looking at 120-200 to replace the wheel bearing at least, so get out the phone book and start calling around.
and btw, you better start saving to replace those CV axles. Once the boots tear, the grease that lubricate the bearings gets flung out. Over time, the unlubed bearings start wearing the races inside out and breaking up, and it'll start clicking and it'll get progressively louder. Eventually, the axle will break, and your car won't move at all.
