NEED HELP... CHanging the head gasket on LS
Old Apr 9, 2007 | 04:33 PM
brandon757's Avatar
brandon757 has disabled reputation
Default NEED HELP... CHanging the head gasket on LS
Old Apr 9, 2007 | 06:21 PM
audiophile24's Avatar
audiophile24 has disabled reputation
Default Re: NEED HELP... CHanging the head gasket on LS
take off head bolts clean thoroughly...check clearance specs for warpage....if alls good install h.g. and torque...then heat head up to 200 or so degrees then re torque head bolts or studs....
Old Apr 9, 2007 | 07:55 PM
RandomTask's Avatar
Head bolts are torque to yield meaning they can only be used once. There should be a tensioner below the water pump, thats how you remove the tension from the timing belt.
Old Apr 9, 2007 | 08:36 PM
tecnic1's Avatar
This is going to spo
tecnic1 tecnic1 tecnic1
http://servage.hondahookup.com/manua...00_01_supp.pdf
I feel nice today and won't make fun of you.
Old Apr 10, 2007 | 04:37 AM
RPRacing's Avatar
Huntin Dropa ForLife
RPRacing has disabled reputation
if you get stuck, call me up and let me do it? 757-575-2416
Old Apr 10, 2007 | 04:43 AM
krazdracer's Avatar
krazdracer has disabled reputation
Well damn, That wasn't in the manual...??????????????
Big Boosta
Want to Buy / Trade ARCHIVE
Jul 17, 2008 02:07 PM
crxtyper
Feb 12, 2008 11:21 AM
Don_is_Rad
Jul 21, 2007 02:47 PM
