need help!!!!! with 98 ek
Old 03-08-2011, 01:22 PM
onesick97ek's Avatar
onesick97ek onesick97ek onesick97ek onesick97ek onesick97ek onesick97ek onesick97ek onesick97ek onesick97ek onesick97ek onesick97ek
Default need help!!!!! with 98 ek
CLOSED FIXED PROBELM
onesick97ek is offline
Old 03-08-2011, 01:28 PM
L_U_C_K's Avatar
L_U_C_K L_U_C_K L_U_C_K L_U_C_K L_U_C_K L_U_C_K L_U_C_K L_U_C_K L_U_C_K L_U_C_K L_U_C_K
Default Re: need help!!!!! with 98 ek
What have you done to it recently?
L_U_C_K is offline
Old 03-08-2011, 01:32 PM
nothing it has all msd ignition tho. but i dont think that should have anything to do with it. my buddy put my ecu on his car and it made his car idle funny and it threw a CEL on his car, but he could rev his motor past 4500 with my ecu
Old 03-08-2011, 01:36 PM
its just a website
couped's Avatar
couped couped couped couped couped couped couped couped couped couped couped
so what ecu is on your car now.....
couped is offline
Old 03-08-2011, 04:22 PM
i belive the d16y7 manual ecu not sure tho.
Old 03-08-2011, 04:30 PM
baller/dickbutt#69
nftuatn's Avatar
get the number off the side of the ecu..
nftuatn is offline
Old 03-08-2011, 05:34 PM
its just a website
couped's Avatar
what motor do you have
couped is offline
Old 03-08-2011, 07:34 PM
carowmoto's Avatar
carowmoto carowmoto carowmoto carowmoto carowmoto carowmoto carowmoto carowmoto carowmoto carowmoto carowmoto
Does the MSD box have a two step rev limiter or just an adjustable rev. limiter on it that isn't set for your car? Some people us MSD rev limiters for staging and rely on the stock ecu rev limiter to handle over reving the engine. Maybe.....
carowmoto is offline
Old 03-08-2011, 08:05 PM
The cam or crank sensor signal might be dropping out and would get worse with increasing RPM, but that would normally be a lot more random than what you're seeing and would normally trigger a CEL if it's bad enough to act like a rev limiter instead of just a slight miss.
Old 03-09-2011, 06:31 AM
no it doesn't have a 2 step. all it has is a msd ignition coil. msd wires and a msd cap
hondahead
10-14-2011 03:31 PM
mbnevins
01-11-2011 09:44 AM
jdm1.5vtec
03-16-2009 02:07 PM
RotorNotPiston
04-21-2003 07:36 AM
Quick Reply: need help!!!!! with 98 ek
