Need Help...93 plymouth acclaim radio wont power
Re: Need Help...93 plymouth acclaim radio wont power
Do you have power on the red/white wire and on the pink wire? those are the factory colors and also where are you getting a ground from,the harness doesnt have one you should be using the silver mesh cable that was bolted to the back of the factory radio for ground.If you have power on both power wires and your using a good ground and the radio still wont work than the radio is bad.
sircrx
38
04-25-2009 08:46 PM
