need help
Old 02-16-2012, 05:13 AM
steelerfan6898's Avatar
steelerfan6898 has disabled reputation
Default need help
i have a 94 civic ex and the other day it randomly started to bogg down and sputter so i replaced the map sensor and i noticed a minor difference, but im still having sputtering problems and slight bogg down. Could it be that i need to replace the o2 sensor too, theres no unusual sounds from the motor, and it only boggs when i try to give it gas.
steelerfan6898 is offline
Old 02-16-2012, 05:24 AM
superuser
Computer_Nerd's Avatar
Computer_Nerd Computer_Nerd Computer_Nerd Computer_Nerd Computer_Nerd Computer_Nerd Computer_Nerd Computer_Nerd Computer_Nerd Computer_Nerd Computer_Nerd
Default Re: need help
run some $2 injector cleaner through it, clean your air filter, reset the computer by unplugging the battery and turning on the headlights (drains residual charge) and wait before reconnecting and letting it idle for a bit.
do the cheap stuff first before you start randomly replacing parts.
Computer_Nerd is offline
Old 02-16-2012, 05:30 AM
It would be a good idea to test the TPS also. Notice I said "test", not "replace"...
Yep.
Old 02-16-2012, 05:47 AM
what is the tps, and do i disconnect both battery terminals and turn the lights on?
Old 02-16-2012, 05:50 AM
and while the car was running i tryed disconnecting and reconnecting the o2 sensor and nothing happenned, so that means its either dirty/clogged or its bad right?
Old 02-16-2012, 06:19 AM
superuser
throttle position sensor.
yes.
no.
run the injector cleaner through at least a half tank of fuel, first.
Old 02-16-2012, 09:59 AM
In TATTRAT we trust
BOREDOMRULE's Avatar
BOREDOMRULE BOREDOMRULE BOREDOMRULE BOREDOMRULE BOREDOMRULE BOREDOMRULE BOREDOMRULE BOREDOMRULE BOREDOMRULE BOREDOMRULE BOREDOMRULE
My advice is to take it to a shop or mechanic.
BOREDOMRULE is offline
emohodge
12-31-2002 02:46 PM
93foxbody
12-24-2002 10:33 AM
scubaskim
12-19-2002 05:52 AM
B18Tuner
12-12-2002 02:02 PM
matthew senski
11-30-2002 12:17 PM
Quick Reply: need help
