Nasty Sound when turning wheels left or right only when cars running!
無限
Alright lets see here, When Im parked, or driving (driving slow ofcourse so I can hear it) I turn the wheel to the left or right (it will do it right after I slighty turn the wheel) It makes a metal screeching sound. Loud enough to be annoying an noticable (Thats the best way I can describe it, all an all its just an annoying screeching sound) At first I thought It was dust shield hitting tie rod end maybe. But its not. I dont see anything underneath there rubbing. But its only when car is on as ive notice (and it is power steering) so i dont know if it has anything to do with that or not. I know its hard to diagnose with out looking at it so If anyone can throw their 2 cents in an gimme some ideas at what to check that would be appreciated. Thanks again.
WEEEEEEEEEEE
Re: Nasty Sound when turning wheels left or right only when cars running!
U LòÓk Mad !!
did you check ur power steering fluid level?? check that the belt has good tension and check that ur power steering pulley is properly/securely bolted in place.
d00d, try belt dressing!
Haha, no but like everyone else is saying, check your belt and fluid level. In a lot of cars, if you turn the wheel too far you'll get that noise too.
make 7 UP yours
get a can of belt dressing and lube up your rear end, if its still screeching try Mentholatum
all joke aside, I am stepping out of this one....
無限
I was under there yesterday and I found what it was. It was the Bushing thats on the axle in the middle. Stabalizer bushing or whatever. And It was rubbing the underneath of the Alternator bracket. It hard worn through that bracket all the way to the metal and so that metal was what I was hearing. And it was hitting ofcourse sense car is low. I just shoved it up the axle more so It was out of way of that.
Thanks for the 2 cents from everybody!!
fventura03
Exterior
18
06-03-2010 12:34 PM
Kris.Is.Foamin
Want to Buy / Trade ARCHIVE
34
08-04-2008 08:04 AM
