MPFI swap???? Help
Old Jun 12, 2005 | 04:32 PM
skybluecrx's Avatar
*moving on up*
skybluecrx has a reputation beyond reputeskybluecrx has a reputation beyond reputeskybluecrx has a reputation beyond reputeskybluecrx has a reputation beyond reputeskybluecrx has a reputation beyond reputeskybluecrx has a reputation beyond reputeskybluecrx has a reputation beyond reputeskybluecrx has a reputation beyond reputeskybluecrx has a reputation beyond reputeskybluecrx has a reputation beyond repute
Default MPFI swap???? Help
How would you go about doing this swap without using a resistor box? *(is this even possible)
Got the idea from this: http://honda-tech.com/zerothread?id=1275711
if this is possible what parts do I need??
Old Jun 12, 2005 | 07:17 PM
Default Re: MPFI swap???? Help
If you use OBD1 or OBD2 injectors, you don't need a resistor box. What are you asking? What car, what engine, what are you trying to accomplish?
Old Jun 13, 2005 | 12:20 PM
skybluecrx's Avatar
*moving on up*
i have the whole obd-1 setup (injectors, distributor, etc) how would i go about doing a mpfi swap with these parts.
Its a crx dx with a d15b7 motor. All the dual point stuff swapped over on the b7 and wanting to do a mpfi swap using the mpfi stuff if possible.
Old Jun 13, 2005 | 01:06 PM
SlowLS's Avatar
Sumospeed #O.G.
You will need to use obd-1 or 2 injectors. Then you take the 4 yellow wires that would go to the resistor box and wire them together. Then splice the wires wires into the red wires that go to the resistor box. Did it on my b16 setup so I know it works. The red wires are 12v's but obd0 injectors are like 6-8v's so thats why you need the resistor box. However obd1/2 injectors are 12v. I also have a risistor box for sale if you want one. $10
4g4d
Dec 23, 2006 01:56 PM
MarkiSick
Jun 11, 2004 10:23 AM
BLU CIVIC
Sep 17, 2003 09:00 AM
