motor swap help!!
Old Feb 6, 2005 | 07:06 PM
WqYn3's Avatar
repping that gR
WqYn3 WqYn3 WqYn3 WqYn3 WqYn3 WqYn3 WqYn3 WqYn3 WqYn3 WqYn3 WqYn3
Default motor swap help!!
im swapping a 95 ls motor into a 96 civic hatch and i need to know what motor mounts do i need to buy for this? thanks.
Old Feb 6, 2005 | 07:41 PM
M1KeyC's Avatar
M1KeyC is a jewel in the roughM1KeyC is a jewel in the roughM1KeyC is a jewel in the rough
Default Re: motor swap help!!
hmmm not to jack threads but, Im also swapping an LS B18A into my hatch... (1990 DX Hatch )wtf do I need? I read a write up but it dosnt say much of anything
Engine: 1990-1991 USDM B18A1
Displacement: 1834cc
Compression Ratio: 9.2:1
Rod/stroke ratio: 1.54
Hp/Torque: 130hp@6000rpm/121lb-ft@5000rpm
Transmission: S1, Y1, YS1, A1 (91 only) (cable)
OBD: 0
ECU: PR4
The B18A1 is out of 90-91 integras. This is one of the easiest swaps out there especially if you have an Si, Hf, or an EX. If you don’t, then you need to wire for multi-point. That’s it.
These motors are readily available as well. People often swap motors into their 90-91 integras so they have these pretty-much-complete swaps just laying around. You cant find them at engine importers but quite a few people sell them on www.g2ic.com and you could probably find a few at junkyards. I picked up a whole swap minus wiring harness and axles for $500. Cant beat that with a stick, eh? The downside to this is mileage on the motors and the fact that some people swap motors in their integras because the stock B18A is going out the door.
Performance is good. I had a B18a in my civic for a few months and it was a good motor. Great for daily driving and just enough torque for the tight autocrosses we occasionally have. I took it to the drag strip once and netted a 15.1 @ 91mph in two runs at 2240ft above sea level.
thats it... so wtf?
Old Feb 6, 2005 | 07:57 PM
T-Hybrid#2's Avatar
T-Hybrid#2 has disabled reputation
U need motor mount kit look on ebay....An also a shift linkage..Other than that some wiring might be envoled but if your lucky then none.
Old Feb 7, 2005 | 05:36 AM
WqYn3's Avatar
repping that gR
which motor mount kit? better yet which stock mounts do i use. im only puttin my Ls in for the time being untill i get my GSR motor fixed...
Old Feb 7, 2005 | 05:39 AM
crxnfx's Avatar
I have a 20 valve...
www.hondaswap.com
come you guys, research!
Old Feb 7, 2005 | 05:48 AM
WqYn3's Avatar
repping that gR
thanks bro.
sTohc4door
Feb 18, 2009 07:12 PM
94jdm_integra
Jun 29, 2008 09:26 PM
