Motor question for all the Gurus
Old Sep 7, 2004 | 02:15 PM
boostedgsrcivic's Avatar
Stock for Now!!
boostedgsrcivic is an unknown quantity at this point
Default Still need help from Motor question for all the Gurus
i got a b16 turbo 93 civic coupe the speedometer doesnt work and i checked the speedometer its fine and swapped the vss with a good one and it still does the same shit it causing vtec not to work and seems to be fucking up major shit it starts detonating ( i think its detonating) at like 5200 rpms on the dot eveytime HELP ME I NEED IT!
Old Sep 7, 2004 | 02:30 PM
PoS hYbRiD's Avatar
Old School Beast
PoS hYbRiD is infamous around these partsPoS hYbRiD is infamous around these partsPoS hYbRiD is infamous around these partsPoS hYbRiD is infamous around these partsPoS hYbRiD is infamous around these partsPoS hYbRiD is infamous around these partsPoS hYbRiD is infamous around these partsPoS hYbRiD is infamous around these partsPoS hYbRiD is infamous around these partsPoS hYbRiD is infamous around these partsPoS hYbRiD is infamous around these parts
Default Re: Motor question for all the Gurus
i will take a look at it for you , when are you avalible ???
Old Sep 7, 2004 | 05:09 PM
Unplug/disconnect the Vss from the speedo if you can, your speedo might be corrupting the signal and causing the ECU to mess up. Leave the Vss connected to the ECU, and see if the speedo is where the problem is.. You'll prob need a factory manual to figure out where to do that..
Old Sep 7, 2004 | 05:27 PM
Stock for Now!!
im free anytime after 530,and would that cause my car to not engage vtec and detonate its real fuct
Old Sep 7, 2004 | 06:18 PM
probably not detonate, but it may cause it to do some other funny things. There are a bunch of functions in the ECU's program that have to do with the Vss. You may be hearing or feeling something strange having to do with engaging and disengaging VTEC rapidly. Who knows what that would do, the ECU has a good bit of control over how your engine runs, and can make changes faster than your engine can mechanically respond (except for the knock sensor, which samples/averages and takes a while). Anyway, the Vss could cause few problems. My advice would be to not go into VTEC territory until you've done more troubleshooting, as long as the engine is running OK at the moment, so you don't do any more unknown possible damage that you can avoid..
Old Sep 7, 2004 | 06:26 PM
Stock for Now!!
yeah thats why im trying to fix this joint why have all this and drive it like a geo lol
Old Sep 7, 2004 | 08:08 PM
midnightgst's Avatar
Boost makes me happy
midnightgst midnightgst midnightgst
Check your main sensor ground on the thermostat housing
Old Sep 8, 2004 | 03:40 AM
Stock for Now!!
its got a good ground checked that thanks
Old Sep 8, 2004 | 02:53 PM
Stock for Now!!
Old Sep 9, 2004 | 02:15 PM
Stock for Now!!
help
