motor problem
i wonder why does my civic motor over rev by it self when i turn on the my engine on with me pressing the gas all i did was hold the clutch and turn the key and the motor just went over 7 rpm and it over rev with me pressing the gas pedal why does it do that ??
Originally posted by lowcivic
i turn on the my engine on with me pressing the gas...with me pressing the gas pedal why does it do that ??
it should be barely open at a slight angle with a little space for air to pass, you prolly need to clean that bitch, its stuck open, your throttle cable should be pretty tite considering the throttle body is open,spray some throttle body cleaner in there and see if that helps.........the throttle plate should be pretty much vertical when the car starts, when you are at w.o.t it should be horizontal.........
oh oka weh i took off the mass air hose and look inside of the throttle body it was way open when the gas pedal cabel is tight with out me touching the pedal the cable is tight is it suppsoe to be loose when not pressing the gas ?
so the throttle plate gotta be close ?
. Do you know how to drive a 5 speed?
