Motor mounts?
Old Mar 7, 2003 | 11:52 PM
rsxintheblood's Avatar
rsxintheblood
Default Motor mounts?
i have an rsx and i broke a motor mount bolt. What is a good place to take it to, to get it fixed. besides acura. its to expensive and well to much work to put the car back to stock.
Old Mar 8, 2003 | 05:01 AM
JBub's Avatar
It's Duck Season
JBub JBub JBub JBub JBub JBub JBub JBub JBub JBub JBub
take it back to acura, you dont have any aftermarket parts that would void your warranty on your motor mounts.
Old Mar 10, 2003 | 05:04 PM
rsxintheblood
i ordered the bolt and i am doing it myself. Also ordered the ES motor mount inserts to try to correct the problem from happening again.
Old Mar 10, 2003 | 09:23 PM
urvtecs2slo's Avatar
i like prom.
dont you have 2 other bolts holding the mounts to the engine?
Old Mar 10, 2003 | 10:08 PM
rsxintheblood
i have 4 motor mounts. but the one on the passanger side has 2 bolts attached to it. one bolt broke on that side. it the one attached to the block it's self.
Old Mar 10, 2003 | 10:10 PM
rsxintheblood
its not the one to the engine that broke. its one of the studs that comes up out of the braket attached to the block. the studs are then screwed down to another broket that attaches it to the frame of the car at the top of the engine bay
Old Mar 10, 2003 | 10:34 PM
g S x's Avatar
RIP Chris Schader
g S x g S x g S x g S x g S x g S x g S x g S x g S x g S x g S x
Have you tried York Bolt?
Old Mar 11, 2003 | 04:01 AM
i like prom.
ok, cause i was about to say one bolt wont matter unless youve got mad vibration, but the bolt to the block should be fixed.
Old Mar 11, 2003 | 08:07 PM
rsxintheblood
the bolt to the block is fine. It is the stud that is attached to the mount which is bolted to the block. And aslo the bolt will be here friday. which sucks i had a mustang try to race me on my home from work and i couldnt because of the mount. grrrrrr
hatchback91joey
Engine / Exhaust / Drivetrain
Feb 13, 2009 06:32 AM
buugiewuugie
Want to Buy / Trade ARCHIVE
Mar 31, 2008 09:53 AM
cleanEK
Jan 3, 2008 05:13 PM
