maintenance required.
Old Nov 18, 2004 | 05:12 PM
urvtecs2slo's Avatar
i like prom.
Default maintenance required.
for a 96 civic.
does anyone pay attention to the maintenance required light, which on my car, is now red? i cant imagine there would be much else required to fix or replace considering ive had my timing belt, ac belt, plugs and wires, air filter, etc replaced in the 8 months that ive had the car. so, my question is, should i ignore it, or take it in somewhere?
Old Nov 18, 2004 | 05:13 PM
Woodrow's Avatar
Slow as Shit
Default Re: maintenance required.
It goes off to remind you of an oil change. It has to be reset after you perform the oil change.
Old Nov 18, 2004 | 05:14 PM
MORE IMPATIENT's Avatar
DESTROYS DONUTS !!
erase the code...it usually keeps track of the little things..there should either be a button underneath the drivers underside dash panel that youll need to hold in and turn the secondary ignition on or it should be in your manual how to erase it, on your i think you have to put the key in the ignition and press the button next to it, maybe that was on the year before yours, it should be in your manual how to erase it, but the service writers usually wont tell you that........
Old Nov 18, 2004 | 05:16 PM
.eric.'s Avatar
.eric. .eric. .eric. .eric. .eric. .eric. .eric. .eric. .eric. .eric. .eric.
Try this...
1) Put the key in the ignition without turning.
2) Press and hold the odomoter reset button.
3) Turn the ignition key to the on position without starting the car, continuing to hold the reset button.
4) Hold the reset button until the light goes out - approx. 10 seconds.
Originally Posted by urvtecs2slo
for a 96 civic.
Old Nov 18, 2004 | 05:17 PM
zexpwrd4door's Avatar
R E U P Gang
zexpwrd4door zexpwrd4door zexpwrd4door zexpwrd4door zexpwrd4door zexpwrd4door zexpwrd4door zexpwrd4door zexpwrd4door
Stick yur ignition key in the slot next to it. It will flip back to green. That thing changes color with the mileage corresponding with the maintence suggested for that time period in your manual.
Old Nov 18, 2004 | 05:20 PM
i like prom.
thanks for all the suggestions.
now, being that all the suggestions are quite different, does anyone know if any of these actually work?
Old Nov 18, 2004 | 05:25 PM
R E U P Gang
I have a 96 civic I know it works go out there and do it....it looks like a little window right? and then theres a black slot next to it?
Old Nov 18, 2004 | 05:42 PM
gear's Avatar
Die reinste Bösen.
im having the same fucking problem in my 95 integra....i cant find the button to get rid of it though.
Old Nov 18, 2004 | 06:41 PM
pimpingreen13's Avatar
pimpingreen13 is an unknown quantity at this point
I also have the same prob in my 95 integra at first it used to flash for a couple of seconds when I started the car but now it just stays on.
Old Nov 18, 2004 | 06:51 PM
R E U P Gang
Dont know bout teggys but civics are manual not on the instrument electronics
