ls/ vtec question
Old Dec 18, 2004 | 12:31 PM
SmallBlock_DC2's Avatar
time for a change
SmallBlock_DC2 is an unknown quantity at this point
Default Re: ls/ vtec question
Originally Posted by Hybrid_vtec
True. A P72 will bump up your compression and AEBS, Blox, Wicked Industries, and Skunk 2 all make IM for the GSR head. As far as Pistons go, if you want extreme you can use CTR pistons(with CTR's you have to machine either the rod or the piston 1mm to make fit) for really high compression or P30(JDM B16; will fit with no machining) for a lil bump in Compression. Also I recommend shotpeening the rods and use ARP 8mm rod bolts since you will more than likely take the motor over 7400 rpms.
thanks for the info bro, sounds like a good plan
Old Dec 18, 2004 | 02:24 PM
Dara's Avatar
Dara is an unknown quantity at this point
go b16 shane...
(but no matter what, its still on in 2 months.........)
Old Dec 30, 2004 | 07:45 PM
BrokeAssCrix's Avatar
ballslickem!
BrokeAssCrix BrokeAssCrix BrokeAssCrix BrokeAssCrix BrokeAssCrix BrokeAssCrix BrokeAssCrix BrokeAssCrix BrokeAssCrix BrokeAssCrix BrokeAssCrix
Originally Posted by Dara
go b16 shane...
gsr should yield the highest compression ratio... i could be crazy here. higher comp = more power. you want the highest cr possible without the piston wacking the head or the valves colliding. and most b16 heads u dig up are older than dirt, thusly the springs are sacked out and can lead to valve float at high rpm... no good
Old Jan 12, 2005 | 12:12 PM
time for a change
any more ideas?
Old Jan 12, 2005 | 04:45 PM
Grease Monkey's Avatar
Grease Monkey Grease Monkey Grease Monkey Grease Monkey Grease Monkey Grease Monkey Grease Monkey Grease Monkey Grease Monkey Grease Monkey Grease Monkey
You would probably get the best power gains from a D15 head.
Old Jan 12, 2005 | 05:05 PM
Veritas's Avatar
MLB! Lets GO!
Veritas Veritas Veritas Veritas Veritas Veritas Veritas Veritas Veritas Veritas Veritas
i got that sport compact car issue if u want it shane...
its got a pretty in depth section on it....
Old Jan 13, 2005 | 04:08 AM
time for a change
ill take it Steve.....thanks
Old Jan 13, 2005 | 04:09 AM
time for a change
im wondering if i could run itr pistons in an ls/vtec??
Old Jan 13, 2005 | 04:22 AM
LSturboEH2's Avatar
LSturboEH2 is an unknown quantity at this point
u can, but i know some people have run into problems with clearance. this was then they advanced timing.
back when i was ls/vtec here is what my plan what. maybe it will help you.
B18 Block
P30 (usdm b16a3) pistons
Shotpeened ls rods
any form of Vtec head
Golden Eagle LS/VTEC Kit (included sandwhich plate and dowels so u dont have to drill the head and all the lines and -an fittings you need)
B16A3/2 Transmission (GSR would also work)
GSR Cams
GSR ARP Head Studs
LS HeadGasket
P30 Intake Manifold
Any 4-1 Header
B16A3 Distributor
P72 ECU (made a HUGE difference over P28 or P30)
The B16A3 Came in the DEL SOL DOHC VTEC model and u can get it in OBD1 (if ur running OBD2 i suggest P2T which is B16A2 00-99 SI) or (if u run OBD0 get the B16A JDM crx/civic sir or teg xsi parts)
if u have any questions i still have alot of information from when i was doing this build up and u can im me on AIM at LUGmyNUTS
Old Jan 13, 2005 | 06:22 AM
SCOOBY STEVE's Avatar
sup
SCOOBY STEVE SCOOBY STEVE SCOOBY STEVE SCOOBY STEVE SCOOBY STEVE SCOOBY STEVE SCOOBY STEVE SCOOBY STEVE SCOOBY STEVE SCOOBY STEVE SCOOBY STEVE
Don't forget to grab a block girdle.
