ls/vtec need help!!!!!!!!!!
Ok heres the deal. I bought everything i need for ls/vtec motor wise. I have the ls head gasket. The oil lines and fittings. The gsr water pump and timing belt and valve cover gasket. I also got an obd0 to obd1 jumper harness to use. Im using a p28 ecu. I have a b17 head.
Now the problem i am having is wiring for the distributor. I dont know what kind of dizzy i need. Do i have to use an obd1 dizzy since im using an obd1 ecu? or can i use an obd0 dizzy with a obd1 ecu? im not sure what to do? if i get an obd1 dizzy do i need any type of jumper harness for it or what will be required for me to take car of it i need help and quick
Re: ls/vtec need help!!!!!!!!!!
everything is going into a 90 da integra. so it is 0bd0 i have someone who is supposed to do my motor but i like to know how everything needs to be done its easier for me to learn this way. and how hard is it to repin a dizzy
Sumospeed #O.G.
The obd1 pins will not fit in the obd0 clip. You can buy a jumper harness or make your own like I did. it is pretty easy. Or just cut the plug off you dizzys and solder them obd0 plug on the obd1 dizzy.
