LS/VTEC help "lope" problem
Old Jun 18, 2008 | 11:46 AM
ChirpinSecond's Avatar
ChirpinSecond has disabled reputation
Default LS/VTEC help "lope" problem
I just did a swap for a buddy and this is all kinda new to me....
We got the motor together and running last night. The car runs good and pulls good.
My only question is a idle the car starts to "lope" or "cam". I know that this is usually caused by a vacuum leak but it looks like they are all up to par. The head is a gsr head with gsr cams. Do gsr cams produce this or is this something else.
Thanks alot
Old Jun 18, 2008 | 11:55 AM
ryanherington's Avatar
yaaat.
Default Re: LS/VTEC help "lope" problem
What's it idling at?
Old Jun 18, 2008 | 12:16 PM
CIVIC2C's Avatar
WWW.TEAMDOHC.ORG
CIVIC2C has a little shameless behaviour in the past
Make sure your timing is correct make sure your t-belt hasnt jumped a tooth.
Old Jun 18, 2008 | 02:03 PM
Is it idling rough, or is the idle surging up and down?
Old Jun 18, 2008 | 03:33 PM
Slow EG8's Avatar
Slow EG8 has disabled reputation
idle air control valve perhaps.
Old Jun 19, 2008 | 02:42 AM
Its idle surging, thanks for the correct word. The IAC is fine, I just rechecked the timing and its still TDC. Its idle is at about 900rpms.
Old Jun 19, 2008 | 09:05 AM
What kind of flywheel? Have you calibrated the throttle position sensor yet?
Old Jul 2, 2008 | 06:47 AM
yeah we calibrated everything. I adjusted the idle a little and seems to not do it as much.
SOHC_CriX
Nov 7, 2008 06:31 PM
Hondasi88
Jul 26, 2008 03:08 PM
kf91da9
Dec 7, 2007 08:33 AM
