LS Swap in EF HELP!!
Old Dec 19, 2008 | 11:58 PM
civic4lyfe's Avatar
civic4lyfe has disabled reputation
Default LS Swap in EF HELP!!
ok i basically have everything besides the wire harness and shift linkages.... i know i need a obd0 to a obd1 wire harness but im not sure. can someone please tell me or verify to me on what wire harness i should get that would fit perfect in my car.... another question is what is a mpfi?...
Old Dec 20, 2008 | 10:18 AM
MajorsEF's Avatar
MajorsEF will become famous soon enough
Default Re: LS Swap in EF HELP!!
Well first you need to know what year this B18 is. If its OBD0 then you can use your current harness and would just have to convert to mpfi. If its a OBD1 motor then you would have to change some plugs, such as the distributor plugs. MPFI= multi port fuel injection. Your car comes from the factory with 2 injectors, which is DPFI, dual port. When you convert to MPFI you manually wire in two(2) more injectors. If your on a budget you can do all this wiring yourself. If your not on a budget then you can get a harness from Rywire. I brought one from them, its great. It will run you about 500$ for everything you need. I recommend you convert to OBD1 while your doing all this. If you go the Rywire route, it will include the OBD0-1 ecu jumper, and OBD1 engine harness. Good Luck
Old Dec 20, 2008 | 11:14 PM
civic4lyfe's Avatar
its a 92 LS Block so i think it is a obd1... hey by any chance do u have for sale anything like the shift linkages i need?...
Old Dec 21, 2008 | 12:24 AM
MajorsEF's Avatar
nope sold it..sorry. and yes if its a 92 then it is obd1 so you have a lot of wiring to do. convert everything to obd1. if i remember correctly all you need to change is the dizzy plugs, and buy the obd0-1 jumper from boomslang/rywire/ebay...wherever
sTohc4door
Engine / Exhaust / Drivetrain
Feb 18, 2009 05:23 PM
vtec2.0
Oct 31, 2008 11:10 PM
