LS into EF body
Re: LS into EF body
hasport mounts
hasport shift linkage
stock civic harness
integra (DA) axles and half shaft
integra (DA) ecu
motor & trans
you can not use the integra harness, it will not plug up to the civic chassis.
DX and SI models do not need to change hubs.
search on here and honda-swap.com for more info on wiring.
stock civic harness
integra (DA) ecu
motor & trans
Re: LS into EF body
Ef Bseries swap mounts
Ef bseries swap shift linkage
Stock harness modified for multipoint
ecu obd0
also sometimes the crank pulley might rub the outside of the fender (it did for me) so i just pushed it in just a tad
ecu obd0
Re: LS into EF body
i had a problem with 2 of my ef's requiring one axle out of a 86 integra and then i did another ef that both Da axles worked lol so if one of your axles seems to be to long go pick up a 86 axle its a tad bit shorter.a friend of mine had the same problem in his crx
