LS into EF body
Zombies found Waldo
LS into EF body
I have a wrecked Integra w/ 85k on the motor and tranny. I have wiring harness ecu. EVERYTHING. What do I need to buy to swap the ls into the EF. I was told just HASPORT motor mounts. But then I read that the stock integra mounts will work? is this true?
Re: LS into EF body
if you have a hf crx or civic hatchback std, he needs the hubs. What year integra did the motor come from? Need mounts for b series into a ef, shift linkage. Maybe more depending on what year it came from. If the ef still has the dual point motor you have to do the dual to multi point conversion also.
Re: LS into EF body
hasport mounts
hasport shift linkage
use stock harness from the 91 civic, add some wires and extend some
we can have it done dfor you in a day if you want to bring it by
Redline Customs
8176 elm drive
mechanicsville va 23111
804-559-3503
Redline Customs
8176 elm drive
804-559-3503
Zombies found Waldo
Re: LS into EF body
