lowering
Old Jan 2, 2010 | 05:30 PM
  #21
Cyanide Jello's Avatar
Zerofucksgiven
Default Re: lowering
Originally Posted by Fabrik8
There is no "right way" to modify a spring. If you cut it, anneal it, close and grind the end, and heat treat it, you now have a spring that's the same spring rate as the old one but shorter. So you have the same spring rate and less spring travel.
If you anneal it, heat it, compress it, and heat treat it, you now have a shorter spring with almost the same spring rate but less travel before it goes into coil bind.
If someone can suggest a way to modify a pre-made spring without horribly compromising the spring design and performance, I'd love to hear about it.
In all honesty though, if the coilover doesn't go low enough for your tastes, get different coilovers. If you shorten the spring, you're getting really close to bottoming out the damper on even small bumps. Just like the old NASCAR joke that vehicle dynamicists like to tell, "any suspension will work if you don't let it"...
This isn't like putting lowering springs on stock-length struts. Coilovers are designed to have travel over the whole adjustment range of the spring that they come with. Change the spring length, and who knows where you stand..
There are all kinds of coilovers on the market that are specifically designed for going impractically low without any concern for actual suspension performance. Just buy some coilovers like that.
You are right sir... But having professionals "collapse" a spring to give you a lower ride is better than doin the old skool heating or cutting...
Old Jan 2, 2010 | 06:31 PM
  #22
But that doesn't excuse the fact that you shouldn't be modifying the length of a spring that the coilover was designed for.....
Old Jan 2, 2010 | 06:56 PM
  #23
Zerofucksgiven
I understand this... But what I suggested was a more correct way to do what the OP had in mind... *shrug*
Old Jan 2, 2010 | 07:00 PM
  #24
B-Well's Avatar
I Love to Hate
agreed but at what cost is he going to modify his 20 dollar coils?
Old Jan 2, 2010 | 07:03 PM
  #25
Zerofucksgiven
That'd be somethin he'd have to look into... OP is local so he could just stop by there... I must've missed the part where he had cheap coils... If thats the case, its not worth the hassle...
I hate to take this off topic, but, OP what do you drive? I see you're in Roanoke...
Old Jan 2, 2010 | 07:12 PM
  #26
B-Well's Avatar
I Love to Hate
not only literal cost. what price will the rest of his vehicle and suspension pay for incorrectly modifying such an important component that is used 100% of the time?
Old Jan 2, 2010 | 07:17 PM
  #27
Zerofucksgiven
I'm not entirely sure of that either... I'm pretty sure the guys down at RSW would set him straight... They know their shit pretty well and I hear only good things come from down there... So I'm sure they'd take into account the struts travel capacity... I don't think they'd leave him riding on struts...
Old Jan 4, 2010 | 05:49 PM
  #28
hatch22's Avatar
hatch22 is infamous around these partshatch22 is infamous around these partshatch22 is infamous around these partshatch22 is infamous around these partshatch22 is infamous around these partshatch22 is infamous around these partshatch22 is infamous around these partshatch22 is infamous around these partshatch22 is infamous around these partshatch22 is infamous around these partshatch22 is infamous around these parts
they are pretty shitty and not worth the hassel ...... so problem solved ill just buy a new set up i was lookin any way and doug you know me im the guy in the black four door and the h22 swapped civic live in vinton
Old Jan 4, 2010 | 08:18 PM
  #29
Zerofucksgiven
I do? *scratches head* Maybe? I'm drawing a blank...
Old Jan 4, 2010 | 08:29 PM
  #30
B-Well's Avatar
I Love to Hate
you're that popular. people know you haha
