Links for water injection used by GN's and MR2's
Old May 21, 2003 | 07:18 AM
Greaser's Avatar
Greaser has a reputation beyond reputeGreaser has a reputation beyond reputeGreaser has a reputation beyond reputeGreaser has a reputation beyond reputeGreaser has a reputation beyond reputeGreaser has a reputation beyond reputeGreaser has a reputation beyond reputeGreaser has a reputation beyond reputeGreaser has a reputation beyond repute
Default Links for water injection used by GN's and MR2's
Theres a company out there that makes its own water injection kit. Alot of grand national owners use it. It has its own controler for motor speed, pressure switch and low water level warning. it comes in a 1 or 2 gallon jug with a fuel pump mounted inside. its pretty hot but i cant find that link to the company
can you guys help me out?
Old May 21, 2003 | 07:24 AM
Heat's Avatar
HAM
Heat Heat Heat Heat Heat Heat Heat Heat Heat Heat Heat
www.turbobuick.com
Old May 21, 2003 | 07:27 AM
sprayn93's Avatar
sprayn93 sprayn93 sprayn93 sprayn93 sprayn93 sprayn93 sprayn93 sprayn93 sprayn93 sprayn93 sprayn93
Snowperformance makes a water/ meth injection.
Old May 21, 2003 | 07:35 AM
Carter's Avatar
nannerpus, nannerpus
www.H2Oinjection.com
Old May 21, 2003 | 07:59 AM
montman's Avatar
Biding time
montman is infamous around these partsmontman is infamous around these partsmontman is infamous around these partsmontman is infamous around these partsmontman is infamous around these partsmontman is infamous around these partsmontman is infamous around these partsmontman is infamous around these partsmontman is infamous around these partsmontman is infamous around these partsmontman is infamous around these parts
Here are a few:
http://www.snowperformance.net/
http://www.smcenterprises.com/index.htm
http://www.aquamist.co.uk/cp/cp.html
couple of blown modulars in the area are using them.
Old May 21, 2003 | 08:37 AM
Greaser's Avatar
Montman got it!!!!!
smc enterprises has the piece i was talking about. THANK YOU!
Old May 21, 2003 | 09:41 AM
MA-HALF-E's Avatar
Awesome.
Does he win a prize?
Old May 21, 2003 | 09:52 AM
Mr.2's Avatar
i probably hate you
Mr.2 is infamous around these partsMr.2 is infamous around these partsMr.2 is infamous around these partsMr.2 is infamous around these partsMr.2 is infamous around these partsMr.2 is infamous around these partsMr.2 is infamous around these partsMr.2 is infamous around these partsMr.2 is infamous around these partsMr.2 is infamous around these partsMr.2 is infamous around these parts
aquamist makes awesome systems
Old May 21, 2003 | 10:25 AM
montman's Avatar
Biding time
No problem at all.
No, you cant have my cookie.
..................or dave's trophy. ...I know you want it.
Old May 21, 2003 | 03:41 PM
Ninety7GSX's Avatar
No Name Who?
Ninety7GSX has disabled reputation
That kit is pretty nice.
I'm gonna try the old route first. All I need now is a pump, a braided line and the nozzle. I've got the pressure switch, a washer fluid tank (will fit on a frame rail perfect), some of the fittings, one way valve and hopefully all the rubber line.
I can't wait to play with it.
