Lightweight flywheel worth it?
Old May 21, 2005 | 10:06 PM
  #21
Qwiksillva's Avatar
Qwiksillva Qwiksillva Qwiksillva Qwiksillva Qwiksillva Qwiksillva Qwiksillva Qwiksillva Qwiksillva Qwiksillva Qwiksillva
Default Re: Lightweight flywheel worth it?
Well, speaking of the bad results of lightening your stock flywheel... I believe my clutch basically broke off into lodging itself into my flywheel... it's the only thing that's making sense, but I havn't pulled it apart to look just yet.
My manifold just came in...
Old May 22, 2005 | 09:20 AM
  #22
Carter's Avatar
nannerpus, nannerpus
SSAC?
Old May 22, 2005 | 12:07 PM
  #23
MKNTRAXX's Avatar
What FMIC?????
MKNTRAXX MKNTRAXX MKNTRAXX MKNTRAXX MKNTRAXX
Originally Posted by eghatchb18
A lightweight flywheel is defiantly a good investment, but for the record even though you probably were not going to do this, getting a stock one lightened is one of the worst things to do. Iv seen some nasty results.
Very true.. You take all this material away from the stock one it won't dissipate heat as well... This causes it to get hot from use(esspecially slipping it on the drag strip and racing).... then you warp your flywheel and burn up your clutch.
TypeSTurbo
Sep 1, 2008 09:01 AM
MarkiSick
Feb 22, 2005 07:29 PM
