k20 tranny problem
Old Aug 10, 2006 | 05:27 PM
Visualimpact757's Avatar
Hardly working
Visualimpact757 Visualimpact757 Visualimpact757 Visualimpact757 Visualimpact757 Visualimpact757 Visualimpact757 Visualimpact757 Visualimpact757 Visualimpact757 Visualimpact757
Default k20 tranny problem
Well not knowing anything about k series motors, it seems to me that first gear is GONE!. 2nd through 6th and reverse work perfect. I was driving home the other night and everything was fine. Then when i was at a stop light i tried putting it into first gear, and it wouldnt go in for nothing. So then i just mess around and think nothing of it. Anyway to shorten the story it finally went in after about 30 minutes of trying last night. Well tonight i was coming home from work and it stopped going into first once again. Well when i get home i jack up the driver side of the car and check tranny fluids. Well i open up the filler plug and about 1/2 quart to 1 quart of oil comes out of the filler plug. I know u are suppose to only fill the car til some start to trickle from the filler. so i figure that was the issue, so i drop it back down and try and nothing at all. Well when the night progressed it went into first gear but as soon as i let my foot slowly off the clutch it poppes into nuteral. Tried repeaditly and same thing over and over it just pops straight out into nuteral. All other gears work perfect. Anyone have any sorta clue to what is going on? I think syncros are shot, but yea any other advise would be great....
Old Aug 10, 2006 | 08:39 PM
Jarrod's Avatar
braap braap
Default Re: k20 tranny problem
I know nothing of K transmissions.
But on B Series. There is a filler hole and a drain hole.
You probably opened the drain hole.
Try doing a complete flush, and see what happens.
Old Aug 11, 2006 | 01:05 AM
Hardly working
no i opened the filler hole. It was the higher up one. I know b series as well
00civicrr
Engine / Exhaust / Drivetrain
Feb 3, 2009 05:12 PM
00civicrr
15
Jan 15, 2009 05:32 PM
hatchn1.6
Want to Buy / Trade ARCHIVE
May 12, 2008 10:47 AM
