Issue/Question
Old Jan 22, 2010 | 04:06 PM
kingmenelik's Avatar
GOT IT FOR CHEAP
kingmenelik kingmenelik kingmenelik kingmenelik kingmenelik kingmenelik kingmenelik
Default Issue/Question
well i blew my HeadGasketthe other day.I have a 1989 crx Si D16A6 and i have a cheap ebay turbo setup..My question is does me having stock internals have something to do it and if so what should i be looking to invest into so the problem doesnt happen again.
Appreciate any positive feedback
Old Jan 22, 2010 | 05:47 PM
backtoarms's Avatar
backtoarms backtoarms backtoarms backtoarms backtoarms backtoarms backtoarms
Default Re: Issue/Question
Use High temp RTV sealant for a new headgasket. Make sure to get some around the valves. It'll make for a MUCH tighter seal.
Old Jan 23, 2010 | 12:50 PM
JB@RameyBuilt's Avatar
Ramey Built
JB@RameyBuilt JB@RameyBuilt JB@RameyBuilt JB@RameyBuilt JB@RameyBuilt JB@RameyBuilt JB@RameyBuilt JB@RameyBuilt JB@RameyBuilt JB@RameyBuilt JB@RameyBuilt
WHAT?!?!?!? Is that a serious post?
There's a reason the head gasket blew. Did the car over heat or something? How many pounds is it on? How many miles are on the motor?
Old Jan 23, 2010 | 12:52 PM
RameyBuilt's Avatar
VAdriven Sponsor
RameyBuilt RameyBuilt RameyBuilt RameyBuilt RameyBuilt RameyBuilt RameyBuilt RameyBuilt RameyBuilt RameyBuilt RameyBuilt
i think i might put this in my sig lo fucking l
Old Jan 23, 2010 | 02:10 PM
Too high of a compression ratio with a turbo causing too much cylinder pressure is the likely cause, coupled with an engine that I assume had a lot of miles on it.
Old Jan 23, 2010 | 06:12 PM
redhatch8u-up's Avatar
Blah Blah Blah
redhatch8u-up is infamous around these partsredhatch8u-up is infamous around these partsredhatch8u-up is infamous around these partsredhatch8u-up is infamous around these partsredhatch8u-up is infamous around these partsredhatch8u-up is infamous around these partsredhatch8u-up is infamous around these partsredhatch8u-up is infamous around these partsredhatch8u-up is infamous around these partsredhatch8u-up is infamous around these partsredhatch8u-up is infamous around these parts
you could run a thicker headgasket (to lower overall compression) and use head studs (for better sealing). The best thing to do would be have a motor built to handle your power goals and get some reliable components.
Old Jan 23, 2010 | 07:08 PM
gpeele's Avatar
still alive
gpeele gpeele gpeele gpeele gpeele gpeele
Depends on the tune also. You may have a condition where your tuning is too aggressive, what kind of A/F ratios and timing are you running? What kind of boost controller do you have, do you know if you were spiking? What do your plugs look like, are any of them overheated at all? Like fabrik8 and redhatch8u-up said you may want to invest in refreshing your motor and fuel system.
Old Jan 23, 2010 | 09:18 PM
backtoarms's Avatar
Soo serious! LAWLZ.
Old Jan 23, 2010 | 09:21 PM
backtoarms's Avatar
I really hope he didn't take my (sarcastic) advice...
temp2
Dec 6, 2008 11:25 AM
gsr-turd
Oct 30, 2007 05:07 PM
Qwiksillva
Apr 28, 2005 10:14 AM
