Issue need help!
Went to start my car and it cut off right away. The check engine light is on but I have no way of getting the code. My car is converted from obd2 to obd1 and I have neither the data link connector nor the dual pin service connector used to check them. I posted a video of what it is doing. As soon as I turn it on it shuts off. The reason the car stayed on the second time was because I was holding the gas down but it would not go over 2000 rpm and as soon as I let off the gas it cuts off. ANY help would be appreciated.
http://www.youtube.com/watch?v=BuEk87yHfUk&feature=youtu.be |
Re: Issue need help!
borrow a s300 and use the error codes on that
Look up an OBD1 pinout and find which wires to jumper together. That's all the service check connector is. It should be a signal wire that gets connected to one of the signal grounds.
Here, I'm feeling generous. According to this, you should connect D4 to either D21 or D22.
http://technet.ff-squad.com/wiring.obd1.htm |
Thanks! I'm gonna try it out
I connected them and couldn't get it to flash..if anyone has any input that would be great
What ECU is it?
P28
Originally Posted by Stinkybean
(Post 8189980)
edit I see the check engine light in the video. |
I might have found the issue. One of the injector wires was bare and was all dirty and rubbing up against the fuel rail. That could have probably been the issue.
