Input shaft bearing d series changed it still making noise
Old 02-14-2013, 03:27 PM
crxmatt's Avatar
crxmatt crxmatt crxmatt crxmatt crxmatt crxmatt crxmatt crxmatt crxmatt crxmatt crxmatt
Default Input shaft bearing d series changed it still making noise
Ok so I have a d16y7 in my wife's 99 and the transmission was making noise
When the clutch pedal was up so I replaced the input shaft bearing and it's still making the
Noise I checked the clearences and bearing play when I had it apart
And everything else was fine I'm clueless right now and a part of me wants to
Brake down and cry any suggestions ?
crxmatt is offline
Old 02-14-2013, 06:57 PM
crxmatt's Avatar
Default Re: Input shaft bearing d series changed it still making noise
Has anyone ever had a problem with the output shaft bearing making a rolling whirrling type of noise.
crxmatt is offline
Old 02-14-2013, 07:16 PM
sixcyl?'s Avatar
sixcyl? sixcyl? sixcyl? sixcyl? sixcyl? sixcyl? sixcyl? sixcyl? sixcyl? sixcyl? sixcyl?
Sounds more like a throw-out bearing to me.
sixcyl? is offline
Old 02-14-2013, 07:31 PM
da4door's Avatar
da4door has disabled reputation
Sounds like throw out bearing
da4door is offline
Old 02-14-2013, 07:49 PM
crxmatt's Avatar
replaced the clutch, pressure plate, throwout bearing and pilot too
the throwout bearing typically would make noise when the clutch pedal is pushed in not when the pedal is up and the
clutch is disengaged
crxmatt is offline
Old 02-15-2013, 04:36 AM
T-Hybrid#2's Avatar
T-Hybrid#2 has disabled reputation
CRXMATT.. I thought a throw out bearing would make noise when the pedal is up then go away once the pedal was pressed down.. ?? Just wondering..?
T-Hybrid#2 is offline
Old 02-15-2013, 04:53 AM
power2weight's Avatar
power2weight power2weight power2weight power2weight power2weight power2weight power2weight power2weight power2weight power2weight power2weight
No throw out will make noise when the clutch is engaged. What kinda throw out did you install? If its eBay you need a new one. Bearings inside the trans make noise when you're in gear and driving, it'll be a whining noise. So if it makes noise in neutral with the clutch engaged its the throw out. Pilots rarely make noise but cause the clutch to be hard to push do to the input shaft not lining up with the center of the crank, if it does make noise it will be while the clutch is dis-engaged.
power2weight is offline
Old 02-15-2013, 04:55 AM
CoryKnowles123's Avatar
CoryKnowles123 has disabled reputation
Check the trans fluid?
CoryKnowles123 is offline
Old 02-15-2013, 05:29 AM
Flatulence
PicovAndropov's Avatar
PicovAndropov PicovAndropov PicovAndropov PicovAndropov PicovAndropov PicovAndropov PicovAndropov PicovAndropov PicovAndropov PicovAndropov PicovAndropov
How about the main shaft bearing?
PicovAndropov is offline
Old 02-15-2013, 07:25 AM
crxmatt's Avatar
I'm starting to suspect that as well just sucks having to take
Everything apart again
crxmatt is offline
Quick Reply: Input shaft bearing d series changed it still making noise
