injectors problem
Old 07-15-2009, 09:01 AM
Racer360's Avatar
Racer360 is an unknown quantity at this point
Unhappy injectors problem
I have 450cc injectors in my integra but there throwing to much gas to the motor what could be the problem? help plz!
car is tuned and all it is turboed injectors are 450cc on a gsr motor and i do have a resistor box .. but the car was like only puffing and what i was told is that the injectors were giving out to much gas that the motor wasnt burning it .. what could be the proble what can i check?
Racer360 is offline
Old 07-15-2009, 11:50 AM
Mindless's Avatar
Mindless is an unknown quantity at this point
Default Re: injectors problem
Is your ecu chipped?
If yes, are you tuned?
Mindless is offline
Old 07-15-2009, 12:26 PM
I have a 20 valve...
crxnfx's Avatar
are you turboed? because if not, your injectors are too fucking big.
crxnfx is offline
Old 07-15-2009, 01:32 PM
Mattb16teg's Avatar
Mattb16teg can only hope to improve
Red face Re: injectors problem
Ding Ding
What do you mean throwing too much fuel on the motor?
Please tell us you didnt just buy some injectors and put them in a stock car?
Mattb16teg is offline
Old 07-15-2009, 02:28 PM
I uh.. I'm hoping that isn't the case. It would be funny though. People do that all the time though, lots of people put a bigger fuel pump and/or fuel pressure regulator on a stock car. Why, I don't know.
Old 07-15-2009, 05:05 PM
wright's Avatar
Even if all of the above were not true meaning that he has a base map for the injectors ect. If they were low impedance injectors and he did not have the resistor box installed wouldn't that make them not work correctly?
Most likely the case is that they were just put in with out a tunable ECU.
wright is offline
Old 07-15-2009, 06:25 PM
Racer360's Avatar
Racer360 is offline
Old 07-15-2009, 06:31 PM
yaaat.
ryanherington's Avatar
did you have it running fine on smaller injectors wile boosted and everything before you put the 450s in?
ryanherington is offline
Old 07-15-2009, 07:45 PM
Mindless's Avatar
"Like only puffing"...what do you mean? Do you have a wideband & gauge?
Mindless is offline
Old 07-16-2009, 07:41 AM
Racer360's Avatar
like if it wanted to start but it dont it jus goes puff puff puff and on
Racer360 is offline
Quick Reply: injectors problem
