idle problems
Car. 93 integra with swapped b20b
Problem. car idles at 3k warm or cold. car also bogs down when driving.
Mods. I/H/E, exedy clutch, 7.5lb flywheel
I just finished my b20 swap into my DA. Car is not throwing any CELs. It will idle at 3k. I unplugged the map sensor and it dropped to 2,200. Plugged it back in and it rose again. I unplugged the IACV and it dropped to just below 2k, plugged it back up and it rose again. Ive tried adjusting the idle screw but it doesnt do anything. I dont know what to do next? Thanks for any advice. Also, anybody in the Hampton/Newport News area is welcome to come take a look at it.
EDIT: Everything is OBD1
Maybe there is a leak somewhere in the intake manifold. make sure everything is tight and that all vacuum lines are in place and secure. even a small hole in one of the vacuum lines can cause problems.
Have you checked the IACV?
Maybe there is a leak somewhere in the intake manifold. make sure everything is tight and that all vacuum lines are in place and secure. even a small hole in one of the vacuum lines can cause problems. get soap and water in a spray bottle and spray all your vac lines to try and find the leak (if there is one)... the water will bubble up at the leaking spot.
however, i did delete the charcoal canister and now there is an open port on the TB.
