idle problem 95 gsr
Old 09-15-2009, 11:10 AM
89Leg2a94Teg's Avatar
89Leg2a94Teg has disabled reputation
Default idle problem 95 gsr
I'm thinking about purchasing a 95 gsr. It has an idle problem though. It will idle fine but. You give it a little gas the rpms go up then sometimes fall really low or sometimes it will die. Seems like an easy fix but I just want to here someone else opinion. Thanks! If you need extra info about the car ill do my best to give i
89Leg2a94Teg is offline
Old 09-15-2009, 12:00 PM
sbdunkz757's Avatar
sbdunkz757 sbdunkz757 sbdunkz757 sbdunkz757 sbdunkz757
Default Re: idle problem 95 gsr
was happening to my old type r, i replaced the alternator which fixed it.... but yours could be something else
sbdunkz757 is offline
Old 09-15-2009, 06:46 PM
rollinonabean's Avatar
rollinonabean has disabled reputation
same exact thing happening to my 95 gsr
hope somebody answers this
rollinonabean is offline
Old 09-15-2009, 06:52 PM
CPL Us Army
jpick_aap_cpp's Avatar
jpick_aap_cpp has disabled reputation
Read up on hondatech theres tons of information on there for similiar or the exact same issues. I'm thinking TPS maybe going bad....
jpick_aap_cpp is offline
Old 09-15-2009, 09:13 PM
Slow EG8's Avatar
Slow EG8 has disabled reputation
check how many volts your gettin to tps. could be an intake leak or could be your distributor goin out (ELD)
Slow EG8 is offline
Old 09-15-2009, 09:21 PM
CPL Us Army
We did have a coupe come into the store the other day one of our commercial account guys was there, adjusted the distributor & ended up being due to faulty plugs.. weird but it helped him out. (plus his were gapped wrong too)
Old 09-15-2009, 11:20 PM
madmike
94jdmgsr's Avatar
94jdmgsr is on a distinguished road
I just fixed my 94 gsr with this same problem! mine was the tps was out of adjustment.check it and see
94jdmgsr is offline
Old 09-16-2009, 10:10 AM
Dunevant07's Avatar
Dunevant07 has disabled reputation
Could be your throttle postition senor had same problem with a old car of mine
Dunevant07 is offline
Old 09-21-2009, 05:43 PM
WhyN0t's Avatar
WhyN0t WhyN0t WhyN0t WhyN0t WhyN0t WhyN0t WhyN0t WhyN0t WhyN0t WhyN0t WhyN0t
tps was the problem for mine
i have a 95 gsr
WhyN0t is offline
Old 09-21-2009, 06:03 PM
I like pictures.
Lookinaround's Avatar
Is the coolant line for the throttle body still hooked up?
Lookinaround is offline
Quick Reply: idle problem 95 gsr
