i need help
Old Feb 7, 2004 | 07:09 PM
bustedhatch88's Avatar
bustedhatch88 is an unknown quantity at this point
Default i need help
i got a d16a6 and every once in a while when my car is warmed up my revs go down but then go back up to about 1000 rpm's. also when it goes up around 1 it goes up and down. its hard to explain but what do you people think it is. please help its pissing me off. thanks
Old Feb 7, 2004 | 08:01 PM
crxnfx's Avatar
I have a 20 valve...
Default Re: i need help
check your vacuum lines, sounds like your computer is trying to compensate. also take a look at your distributor, you might have a worn or a couple of worn pins. if its worn, it will idle funny.
Old Feb 7, 2004 | 08:30 PM
CivicSiDude91's Avatar
CivicSiDude91 is an unknown quantity at this point
heh i got the same problem
Old Feb 7, 2004 | 08:49 PM
where the vaccum line at ?
Old Feb 7, 2004 | 08:56 PM
Carter's Avatar
nannerpus, nannerpus
oh geez...
they're all over the place.
Old Feb 7, 2004 | 09:03 PM
what u mean all over the place ?
Old Feb 7, 2004 | 09:11 PM
sk8rmike's Avatar
Bitches get Stitches
pretty much every rubber hose coming off the intake manifold is a vacuum line. dont touch your car please.
Old Feb 7, 2004 | 09:20 PM
umm can i take them off and clean them out?
Old Feb 7, 2004 | 11:08 PM
99blackcivicsi's Avatar
normally they don't have blockage in them because it is just air flowing through them. if anything pull of the IAC motor and clean that out good with brake clean, adjust idle screw, and check the the vacuume lines for leaks. that is a starting point for every idle control problem
Old Feb 7, 2004 | 11:11 PM
C MY 4D's Avatar
Simple Bolt Ons
C MY 4D is infamous around these partsC MY 4D is infamous around these partsC MY 4D is infamous around these partsC MY 4D is infamous around these partsC MY 4D is infamous around these partsC MY 4D is infamous around these partsC MY 4D is infamous around these partsC MY 4D is infamous around these partsC MY 4D is infamous around these partsC MY 4D is infamous around these partsC MY 4D is infamous around these parts
find another hobby..........
