how do i wire up my b16 pre-obd in my 91 hatch si
can anybody tell me how to wire up my ecu using my stock wiring harness in my 91 civic hatch si? it starts and runs but vtec wont kick in so i basicly need to know how to wire up the vtec to work. also what is the # on the ecu i'm suppose to use i have a pr4 and a pr3 will either of those work to make the vtec kick in once i wire it up?thanks.
you want to use the pr3 .... i can do the work for you ... you will have to run vtec , vtec oil pressure , knock sensor , and one other wire .... ill have to go look it up ... i got the jdm helms manual for the SIR .... its quite easy ... i did my dx harness and adding 2 injectors , resistor pack , vtec wanst hard at all ...
98civicONair
Want to Buy / Trade ARCHIVE
Nov 5, 2007 05:42 PM
