Hood Alignment Problem
Old 11-11-2010, 12:41 PM
Joepiper151's Avatar
Joepiper151 Joepiper151 Joepiper151 Joepiper151 Joepiper151 Joepiper151 Joepiper151 Joepiper151 Joepiper151 Joepiper151 Joepiper151
Default Hood Alignment Problem
Whats up guys, I was looking at my brothers 03 Si the other day and realized that the hood doesnt line up like it used to. The car has never had any front end impacts or anything like that. Anyone have any clues as to where to start trying to fix it?
[IMG][/IMG]
Joepiper151 is offline
Old 11-11-2010, 12:54 PM
emptylotsurfer's Avatar
emptylotsurfer emptylotsurfer emptylotsurfer emptylotsurfer emptylotsurfer emptylotsurfer
Default Re: Hood Alignment Problem
lower the turny things on the ffront peice might help the little black rubber things
emptylotsurfer is offline
Old 11-11-2010, 01:27 PM
emgjsdk1's Avatar
emgjsdk1 emgjsdk1 emgjsdk1 emgjsdk1 emgjsdk1 emgjsdk1 emgjsdk1 emgjsdk1 emgjsdk1 emgjsdk1 emgjsdk1
also the latch on the upper support might need to be bent down
emgjsdk1 is offline
Old 11-11-2010, 04:35 PM
henryt26's Avatar
henryt26 henryt26 henryt26 henryt26 henryt26 henryt26 henryt26 henryt26 henryt26 henryt26 henryt26
has he ever scraped or bottomed out on the lower radiator support.
henryt26 is offline
Old 11-11-2010, 05:52 PM
i've tired to lower the rubber things that didnt work, i dont think hes ever had a bad scrape, He thinks it happened after all the blizzards last winter.
emg. are you talkin about the hood latch?
Old 11-12-2010, 03:34 PM
MyCarHasAbs's Avatar
MyCarHasAbs has disabled reputation
that theory may hold some ground, I've heard of extreme heat and cold warping metal over time.
MyCarHasAbs is offline
Old 11-12-2010, 05:24 PM
No. It doesn't even get very cold there. If it actually was a problem, it would occur in places that actually got cold (or hot, etc), and you would have heard about it by now because the car is 8 model years old.
Check the latch, check the radiator support, check that the hood hasn't slid forward on the hinge bolts, check to see if the bumper actually moved and the hood is fine.
It may be possible that it got warped under the weight of a lot of snow though.. Unlikely, but possible.
Old 11-12-2010, 05:48 PM
Well, not to argue, but clearly it get's cold enough to snow, since he mentioned "blizzard" and all... just saying.
Old 11-12-2010, 06:27 PM
Cold enough to snow isn't very cold... just saying. My car, for example, doesn't turn into a pretzel when it's minus 20 in the winter here. Neither does any other car I've ever seen here, and this is nowhere close to the coldest place in the country or the world. So somehow I don't see a Virginia winter doing anything harmful, blizzard or not.
I'm just curious about where you would come up with an idea about sheet metal permanently deforming because of minor winter temperatures.
Old 11-13-2010, 07:06 AM
Alaright thanks man, i'll give that a try next time i get a chance
Quick Reply: Hood Alignment Problem
