Honda problems
Old Oct 5, 2006 | 03:40 PM
94delsolS's Avatar
94delsolS is a jewel in the rough94delsolS is a jewel in the rough94delsolS is a jewel in the rough94delsolS is a jewel in the rough
Default Honda problems
I got a 94 del sol with a 97 head egale rods je pistons and rings je cam anyway pretty much everything you can think of ported polished head whole bunch of crap clutch flywheel pressure plate but stock tranny
anyway to my problem i just boosted it and its only at 7 pounds right now hence to small of fuel pump and i got millinuim to tune it every thing was running great until now i can feel some weird vibrations in my shifter and the oil light will randomly come on and the car will just die.... also i can he some weird banging noises almost like a rod nokc but it sounds like it comeing from the tranny if not the tranny inder the intake mainfold i have no clue whats going on anyone got any advice
Old Oct 5, 2006 | 04:35 PM
94delsolS's Avatar
Default Re: Honda problems
I asked a honda tech and his response was
"Well it sounds like the v tec pressure sensor solenoide is failing very common for this to fail and cause same symptoms I would check that first "
Old Oct 5, 2006 | 06:11 PM
rice4life's Avatar
rice4life will become famous soon enough
there are some wires on ur starter take them all off and clean em. when u put them back on use some elec grease!!! and yes im serious!
Old Oct 5, 2006 | 06:56 PM
94delsolS's Avatar
but would that couse that type of knocking/banging sound the sound gets louder as more throtle is applied
Old Oct 5, 2006 | 07:56 PM
accordgsr07's Avatar
accordgsr07 has disabled reputation
i know your problem...its a del slo
Old Oct 5, 2006 | 09:25 PM
rice4life's Avatar
no but it should fix ur brake warning light and cutting off
Old Oct 6, 2006 | 02:23 AM
GULLIE's Avatar
GULLIE has a reputation beyond reputeGULLIE has a reputation beyond reputeGULLIE has a reputation beyond reputeGULLIE has a reputation beyond reputeGULLIE has a reputation beyond reputeGULLIE has a reputation beyond reputeGULLIE has a reputation beyond reputeGULLIE has a reputation beyond reputeGULLIE has a reputation beyond repute
who put the engine together?
Old Oct 6, 2006 | 10:28 AM
1rude2l's Avatar
flywheel bolts worked loose by chance for the vibration?
Old Oct 6, 2006 | 10:36 AM
Cpt. Non-Spell's Avatar
Speak&Spell Anyone?
Cpt. Non-Spell Cpt. Non-Spell Cpt. Non-Spell Cpt. Non-Spell Cpt. Non-Spell Cpt. Non-Spell Cpt. Non-Spell Cpt. Non-Spell Cpt. Non-Spell Cpt. Non-Spell Cpt. Non-Spell
agreed with flywheel bolts maybe
Old Oct 7, 2006 | 09:03 AM
94delsolS's Avatar
ye aooil is still coming out ad this time the clutch pedal got stuck to the florr i bet it is the flywheel botls ill take it apart tomorrow
