Honda - CEL Problems
Old May 5, 2003 | 06:01 AM
B16ASilverHonda's Avatar
FredVegas
B16ASilverHonda has a spectacular aura aboutB16ASilverHonda has a spectacular aura about
Default Honda - CEL Problems
Ight, let the problems begin...
I have a ODB2 Car and I have a 94 SIR2 B16A which should be ODB1. Now here is my problem, I have been trying to either get this check engine light to either RESET or FLASH the ECU code, and which both i have been unsuccesful. I would like to flash the code but i have tried EVERYWHERE with a paper clip and nothing. Any Suggestions?
This is my wiring setup (Pic)
Old May 5, 2003 | 07:24 AM
MORE IMPATIENT's Avatar
DESTROYS DONUTS !!
that is an obd2 to obd1 conversion harness correct?........and im no help unless i saw it myself and could look around.........so the code isnt flashing at all, its just staying on the entire time?.......
Old May 5, 2003 | 09:46 AM
FredVegas
its not even flashing, just shutting off..
Old May 5, 2003 | 11:22 AM
DESTROYS DONUTS !!
you could have an igintion mix up somewhere or distibutor gone bad, i mean does it run for a few minutes and then shut off or does it just start up and then shut down automatically?.......
Old May 5, 2003 | 02:22 PM
Where did you get the harness?
Old May 5, 2003 | 03:30 PM
FredVegas
I'll just say autosolutions did my swap, nuff said..
Old May 5, 2003 | 05:16 PM
How about some more info on what is happening, what is the engine doing?
Old May 5, 2003 | 07:44 PM
FredVegas
absolutely nothing...just the CEL is on..has a small anti-freeze leak from the heater hoses, but that is something that is not sensored..
Old May 5, 2003 | 07:48 PM
I'll email you the harness pinout..
Old May 5, 2003 | 07:53 PM
DX What!'s Avatar
DX What! has disabled reputation
Did you put the paper clip or wire prefered into the two wire plug to check the code.........looks like the green plug at the very top right hand of your pic, not entirely in the pic
