help !!!rear disc conversion help 98 civc ???
Old 05-24-2006, 05:31 PM
aacjohnc's Avatar
Default help !!!rear disc conversion help 98 civc ???
iclose
aacjohnc is offline
Old 05-24-2006, 05:41 PM
DESTROYS DONUTS !!
MORE IMPATIENT's Avatar
Default Re: help !!!rear disc conversion help 98 civc ???
Originally Posted by aacjohnc
i need to know if a 94 integra rear disc setup will fit my 98 civic . im pretty sure it will but what parts do i need off the teg instead of the rotors, arms,struts, calipers and hoses ?
yes it will.....and all you need is the rear hubs(rotor assembly), calipers, brake lines and e brake cables and brackets. you dont need the integra rear control arms or struts. just pop off your old drums with what i believe it is a 55 torx bit and some other main socket, may be a 19/21.,cant totally recall though, and swap right over to your civic control arms. and i would also reccomend the integra brake master cylinder and brake booster.
MORE IMPATIENT is offline
Old 05-24-2006, 05:52 PM
aacjohnc's Avatar
i thought i might need the master cylinder and booster. thanks just wanted to make sure.
aacjohnc is offline
Old 05-24-2006, 06:06 PM
import mechanic
sucio7's Avatar
sucio7 has disabled reputation
detach e brake cable with arms and brake lines .swap it all to your civic exept the bottom camber hook every thing up in reverse to when u pulled it out
and u have your convertion
sucio7 is offline
Old 05-24-2006, 06:13 PM
aacjohnc's Avatar
it has already been pulled off the car . im goning to pick it up tomarrow for a 100.00 dollar. is that prety decent for this conversion ? it includes booter and master clyinder
aacjohnc is offline
Old 05-24-2006, 06:48 PM
import mechanic
sucio7's Avatar
yeah i normally charge 300 installed so is not bad
sucio7 is offline
Old 05-25-2006, 02:10 AM
I am SLOW SON !!
Slepping_H22_DC's Avatar
Slepping_H22_DC has disabled reputation
thats damn good. unless its got a million miles on it.
Slepping_H22_DC is offline
Old 05-25-2006, 02:48 AM
F22BJSPECACCORD's Avatar
F22BJSPECACCORD has disabled reputation
ya good pickup cuz if u only do the master and not the booster then it will sit sideways. u can run it that way but u cant have as much fluid in so really, damn good deal
<<>>mike james
F22BJSPECACCORD is offline
Old 05-25-2006, 05:55 AM
aacjohnc's Avatar
thanks guys for all the help realy appreciated. im going today to get it,if for some reason i cant get it then ill let yall know where it is at .
aacjohnc is offline
Old 05-25-2006, 06:23 AM
This is going to spo
tecnic1's Avatar
tecnic1 tecnic1 tecnic1
If you want a decent pedal feel, you want the m/c. The booster won't do a lot for you.
stock MC will make you pedal spongy as shit with those calipers...
also, if you are extremely performance minded, and taking these brakes to the track, you want a 4 wheel disk proportioning valve. For just street driving, no need.
tecnic1 is offline
Quick Reply: help !!!rear disc conversion help 98 civc ???
