(HELP)no dash light or tail lights
Old Dec 15, 2008 | 03:29 PM
shytomboy87's Avatar
shytomboy87 has disabled reputation
Default (HELP)no dash light or tail lights
i bought a wreck 93 EJ1 fixed it and now the dash lights and the tail lights stoped working i put a cd player in it today bit did not hook up the dimmer wire and i have checked the fuse and replaces it even though it was no blown help what else could it be
Old Dec 15, 2008 | 03:31 PM
2jzboi's Avatar
2jzboi has disabled reputation
Default Re: (HELP)no dash light or tail lights
Fuses under dash chk wth tst lite
Old Dec 15, 2008 | 03:32 PM
can some one tell me exactly what number fuse it is i dont have the diagram so im not sure if i have the right one
Old Dec 15, 2008 | 04:18 PM
Isn't it on the back of the fusebox cover?
Old Dec 15, 2008 | 07:29 PM
sircrx's Avatar
Boost is Better
sircrx sircrx sircrx sircrx sircrx sircrx sircrx sircrx sircrx sircrx sircrx
most likely its just a fuse just check them all one by one to see if they're blown. If not then there is a wire behind the radio I think that if it is grounded the lights won't work properly so pull the radio back out and check that.
Old Dec 15, 2008 | 08:54 PM
Nebrido's Avatar
Nebrido has disabled reputation
It's blown fuse.... just make sure that the red/black wire behind the radio is not hooked up.... buy a wiring harness next time
Old Dec 16, 2008 | 02:01 PM
fixed it it was the dimer switch but thanks everyone for trying to help
