help! just bought an DA think somethings wrong with the fuel filter
Old Jun 13, 2008 | 05:03 PM
boosie1's Avatar
boosie1 has disabled reputation
close
Old Jun 17, 2008 | 12:16 PM
boosie1's Avatar
Default Re: help! just bought an DA think somethings wrong with the fuel filter
its not the fuel anyone help
Old Jun 18, 2008 | 08:19 AM
oxidejunky's Avatar
oxidejunky has disabled reputation
possible main relay/ does it stay running when u mash the gas or just run a little bit longer
Old Jun 18, 2008 | 11:02 AM
boosie1's Avatar
yea it stays started once i mash the gas then its fine but sometimes when i go start it like today it started every time
Old Jun 25, 2008 | 11:31 PM
boosie1's Avatar
think its the dizzy need advice
Old Jun 27, 2008 | 05:27 PM
boosie1's Avatar
found problem fixed
Old Jun 27, 2008 | 06:10 PM
pt0wn_4door's Avatar
pt0wn_4door has disabled reputation
can i ask what the problem was? because mines doing kinda the same thing only mine will cut off after awhile of driving, then you wait a little and it will start back up. im thinkin icm or possibly the ignition coil but with work i don't have the time to test them.
Old Jun 27, 2008 | 06:19 PM
Lestar's Avatar
Sup, ladies?
Lestar Lestar Lestar Lestar Lestar Lestar Lestar Lestar Lestar Lestar Lestar
Main fuel relay. When it has a problem starting up, try hitting the mfr located right behind the kick panel. It should help.
This is the main reason why I got my DA with 85k miles for $1500.
Old Jun 27, 2008 | 06:31 PM
boosie1's Avatar
mine was bad spark plugs they had oil on them got new ones and it started right up going to get new head gasket
Old Jun 27, 2008 | 07:10 PM
Fiziks's Avatar
my name is andy.
what the fuck is that.
