Help identifying an issue I'm currently having
I have a 97 Civic LX with type-R swap.
I had an issue last month where my timing belt somehow jumped a tooth. Before that, he replaced my fuel pump because he thought that was the issue. After the guy fixed the timing issue, I now I have this issue where once I start my car when engine cold, the engine dies out. The only way to keep the engine running is I have to hold down the gas for about 4 minutes to warm the engine up. After that, it doesn't die out when I take my foot off acceleration pedal. Here is a video of the issue I'm having: https://www.youtube.com/watch?v=4wxwNbHLkAE Another issue I'm having is when I accelerate, my headlights get bright, once I take foot of acceleration pedal, the headlights go dim. This issue has to be connected because it started at the same time as the other problem. What could this be? I'm hearing it may be the battery, or the alternator. After talking with my friend, he doesn't think it is the alternator because he said my car should die out no matter if the engine is heated or not. He still gave me a spare alternator. Should I get this installed tomorrow or do you think the issue is elsewhere? Hopefully someone can help me out :-( thanks, Jeremy |
Re: Help identifying an issue I'm currently having
Honda ignitions aren't terribly great, my money would be on that.
If you're dealing with a swap, make sure all of the grounds are connected and are not corroded. It's an easy thing to miss during an engine swap.
Originally Posted by Fabrik8
(Post 8296795)
Here is a video I shot today of the issue: https://www.youtube.com/watch?v=4wxwNbHLkAE |
check you ecu.. i seen this problem before... it could be your ecu.. or it could be ur tps not opening the throttle body on start... and check the plug to the tps.. if its not getting the right ohms and ground and right power it will not work either... check that man good luck... if the plug is good then its either the tps sensor or ecu... easy way to check if its the tps.. unplug it if your car starts and stays running its the tps... if it still dont stay running then its your ecu
Also check the coolant temp sensor (for the ECU, not the temp gauge). It is what controls the cold idle enrichment.
Here's another thought: the valve cover came off to do the timing belt, so its possible the plug wires are in the wrong order or got damaged during removal/reinstall. I'm guessing this is something related to incidental damage during the repairs. |
(Post 8296863)
Originally Posted by 92-CivicLX
(Post 8296744)
Or was this your boy jim who did it in his storage unit shop. Did it run after the tbelt was done, or was this immediately after he worked on it and it hasn't been right since that moment? |
Originally Posted by Travis.
(Post 8296977)
Take it back to him?
Or was this your boy jim who did it in his storage unit shop. Did it run after the tbelt was done, or was this immediately after he worked on it and it hasn't been right since that moment? After he adjusted the jumped timing, I started the car and it kept stalling. After about 3-4 minutes of revving and holding down the throttle, the car doesn't stall . |
Originally Posted by speedkingrc
(Post 8296860)
You think maybe a wire got loose? This issue is present on both the ecu I was using years (GSR ecu with jumper harness) and the stock Type R ecu. |
