HELP: coolant problem
Old Aug 23, 2008 | 11:42 PM
92sihatch's Avatar
soon to boost!!
92sihatch has disabled reputation
Default HELP: coolant problem
I have a b18b1 ls swap in a 94 civic hatch, regular bolt ons (header and exhaust, blah blah STOCK for the most part) and i have to keep pouring water in the radiator every 2 days or so...it just eats right through it.
What is going on? is it my headgasket? or something else. Thermostat, maybe? Need this solved asap
Old Aug 24, 2008 | 02:42 AM
tangoDelta's Avatar
uses cruise control
tangoDelta can only hope to improve
Default Re: HELP: coolant problem
Have you noticed any oil in your coolant? That is one sign of a blown head gasket.
Old Aug 24, 2008 | 05:55 AM
.eric.'s Avatar
.eric. .eric. .eric. .eric. .eric. .eric. .eric. .eric. .eric. .eric. .eric.
If your headgasket isn't bad, check for leaks at/by:
  • the radiator/coolant hoses
  • the base of the the radiator or the plug itself
  • the water pump
Old Aug 24, 2008 | 05:58 AM
Atlantis's Avatar
OV-104
  • the water pump
Mine was was coming outta the thermo and hitting the block and evap'ing right from there. Before it was stolen
Old Aug 24, 2008 | 07:57 AM
j4k3's Avatar
holla
Do you see any obvious leaks, or smoke? If not, check your oil to see if its almost a milky brown color.
Old Aug 24, 2008 | 12:44 PM
92sihatch's Avatar
soon to boost!!
I've looked and havent seen any leaks...my oil does kinda look like doo doo chocolate milk tho.
So headgasket?
Old Aug 24, 2008 | 05:32 PM
b16pwrcrx's Avatar
cheeseburger
b16pwrcrx has disabled reputation
yea
Old Aug 25, 2008 | 02:04 PM
DORKO's Avatar
Bearded.
well first thing. water evaporates.
try adding coolant instead of water.
i use 50/50 mix, some people do other combinations.
but water gets hot and boils/evaporates.
Old Aug 25, 2008 | 06:13 PM
judging1's Avatar
judging1 has disabled reputation
milky means head gasket....bad news
Old Sep 1, 2008 | 02:28 PM
92sihatch's Avatar
soon to boost!!
Oh well... I have a new headgasket now..just waiting to buy headstuds and oil now to go ahead and take care of that shit while i got the head off.
