help car wont start!
Old 01-09-2004, 05:14 PM
ultra
UspeedWalt's Avatar
UspeedWalt is on a distinguished road
Default help car wont start!
i gotta 94 hatch Si w/ a JDM GSR swap. The car was running fine one day and it cut off. I have replaced the dizzy once already. the problem is, is that the car wont start, it will crank but wont fire. We have spark, and fuel.. even tried a working dizzy.
someone help me!
i need it running otm, hit me up if you wana help me out!
UspeedWalt is offline
Old 01-09-2004, 05:16 PM
Simple Bolt Ons
C MY 4D's Avatar
C MY 4D is infamous around these partsC MY 4D is infamous around these partsC MY 4D is infamous around these partsC MY 4D is infamous around these partsC MY 4D is infamous around these partsC MY 4D is infamous around these partsC MY 4D is infamous around these partsC MY 4D is infamous around these partsC MY 4D is infamous around these partsC MY 4D is infamous around these partsC MY 4D is infamous around these parts
crank fast????
C MY 4D is offline
nannerpus, nannerpus
Carter's Avatar
how sure are you that you have fuel? have you checked fuel pump fuse? made sure dizzy is on right cycle?
Carter is offline
Old 01-09-2004, 05:17 PM
IC x Prince's Avatar
IC x Prince IC x Prince IC x Prince IC x Prince IC x Prince IC x Prince IC x Prince IC x Prince IC x Prince IC x Prince IC x Prince
are you sure you have spark?
IC x Prince is offline
Old 01-09-2004, 05:29 PM
accuracy1's Avatar
accuracy1 accuracy1 accuracy1 accuracy1 accuracy1 accuracy1 accuracy1 accuracy1 accuracy1 accuracy1 accuracy1
what is the cel doing?
accuracy1 is offline
Old 01-09-2004, 07:15 PM
spooledex's Avatar
spooledex spooledex spooledex spooledex spooledex spooledex spooledex spooledex spooledex spooledex spooledex
timing want to check that?
spooledex is offline
Old 01-09-2004, 07:50 PM
ultra
UspeedWalt's Avatar
cel is fine, spark we got.
but one problem might be that there was some oil on the plugs!??
dont think that, that is good.
checking the timing tom, along with fuses
Old 01-10-2004, 05:42 AM
bye
dirt the flirt.
bye's Avatar
bye bye bye bye bye bye bye bye bye bye bye
are yer o-rings fucked in yer valve cover?
bye is offline
Old 01-10-2004, 05:48 AM
Bitches get Stitches
sk8rmike's Avatar
if you think you see oil on the plugs do a compression test. if that turns out good try new plugs.....also crack the fuel pressure regulator loose a little on the end of the fuel rail and turn the car to the acc position, and when the fuel pump is primed, check to see if fuel shoots out of it....
sk8rmike is offline
Old 01-10-2004, 06:23 AM
Boosted2003's Avatar
yeah also when you replaced dizzy cap did you repalce the rotor inside?
Boosted2003 is offline
Quick Reply: help car wont start!
