help with cam timing
need suggestions on were i should set my cam timing
b16a1 with itr cams spoon ecu full exhaust msd digital6 ignition b&m fuel pressure regulator now there set at retard1 on both i tryed to set them were tim from millenium said (int + 2 1/2 exh-1) and i lost all the power i had so i set them to -1 on both and its better but still has room for improvement any suggestions would be appreciated p.s. dyno'd the car today and it dyno'd at 14.0 all motor spinning in first |
If you had the car on the dyno, why didn't you adjust them while you were there?:confused:
bcause i could only do a 1/4 mile pull it was not a tuning session
