help with 96 integra
it seems when i give the car more than a half throttle it hesitates and slows accel rate until i hit like exactly 3k rpms,and starts pulling like i hit a switch or something, if i granny the throttle it accels fine
any input would be great i dont even know where to start, a sensor? injectors? fuel filter? Has anyone else had this problem with an obd-II integra?
oh yea the car doesent spit out any obdII codes or any warning lights, thanks for any input.
ACCOUNTANT
Re: help with 96 integra
make sure you light even works first by putting the key into the ignition, turn to the 2nd notch without starting the car. the engine light should go on then turn off. if it doesnt come on then you know its burnt. it happened to me, i didnt even know i was throwing a code until i switched clusters.
well my first thought was that you are in limp mode. but you said you didnt throw any codes. but its worth a shot to reset the ecu. you can do so by disconnecting the negitive battery cable for 5-10mins.
have you checked your spark plugs and spark plug wires? once can be messed up causing you to run on only 3 cylinders which has those symptons. my friends car was doing the same thing, and i helped him do a tune up and all is well now. try doing a tune up if you havent done one recently. ie spark plugs, spark plug wires, distributor cap and rotor, fuel filter.
AShotInTheDark9
11-30-2008 10:25 AM
ravenracer
12-08-2007 10:13 AM
