Help! 1988 Toyota Pickup
Old 04-12-2015, 04:26 PM
Hi
Integra2Be's Avatar
Integra2Be Integra2Be Integra2Be Integra2Be Integra2Be Integra2Be Integra2Be Integra2Be Integra2Be Integra2Be Integra2Be
Default Help! 1988 Toyota Pickup
I recently bought a 88 Toyota pickup and just finished swapping the blown motor with another 22re. It has a hard start but does start and runs strong. My issue is while im driving. It feels like it has no power! I can floor it and it goes no where! It is throwing a CEL but I cant find the check connector anywhere! I set the timing with a light and by ear since I couldn't find the connector to jump it. Im sure the timing is off a bit but I feel like its a vacuum issue. If I turn the wheel all the way to one side, the truck shuts off.
Integra2Be is offline
Old 04-12-2015, 05:11 PM
C.R.E.A.M
DOOM's Avatar
Default Re: Help! 1988 Toyota Pickup
Send a PM to this dude https://www.vadriven.com/forums/members/yotarip-4125/ he's a yota god
DOOM is offline
Old 04-12-2015, 05:15 PM
Don't worry about a vacuum problem until you fix (or verify) the timing. There is no need to chase your tail when you already know you have a problem that can cause a severe lack of engine power. Solve the major known problem first, then worry about the peripheral problems.
I found this via Google; if it's accurate it may be some help finding that service check connector.
http://www.troublecodes.net/toyota/t...up-or-4runner/
Old 04-13-2015, 03:50 AM
1UZ Inside
YOTARIP's Avatar
YOTARIP YOTARIP YOTARIP YOTARIP YOTARIP YOTARIP YOTARIP YOTARIP YOTARIP YOTARIP YOTARIP
Thanks but my advise would be to drop a 1UZ in it.
Seriously, He needs to run diagnostics first. Hard start is probably the engine the ecu engine temp sensor.
YOTARIP is offline
Old 04-13-2015, 07:28 AM
Hi
Integra2Be's Avatar
I know I need to run diagnostics but like I said, I can't find that check connector. I've searched all over and it's nowhere to be found. It's not where it's suppose to be. I'll post a picture of the engine bay this afternoon. Hopefully I'm just missing it and someone can point it out.
Old 04-13-2015, 10:10 AM
C.R.E.A.M
DOOM's Avatar
Yes indeed for best results
DOOM is offline
Old 04-13-2015, 12:16 PM
Hi
Integra2Be's Avatar
The check connector is suppose to be right next to the fuse box, correct? If that's the case, its obviously missing but where else could it be? Is it possible that someone could have removed it? Would the truck even run if it was removed?
Old 04-13-2015, 12:30 PM
Don't quit!
Somalia's Avatar
Somalia Somalia Somalia Somalia Somalia Somalia Somalia Somalia Somalia Somalia Somalia
Post Re: Help! 1988 Toyota Pickup
I just had one of these on here Friday, These things rarely die.
Did you open that black box next to the battery and check inside? That looks exactly like the picture.
Somalia is offline
Old 04-13-2015, 12:54 PM
Hi
Integra2Be's Avatar
I did check the black box. this is what I contains..
According to another forum, it should be the gray box outside of the fuse box, as pictured below.
Old 04-13-2015, 01:23 PM
Don't quit!
Somalia's Avatar
Ahhh...weird man. I wonder if you unplug the yellow connector and that's it.
That's odd...
Somalia is offline
Quick Reply: Help! 1988 Toyota Pickup
