headlight problem
Old Apr 19, 2009 | 12:59 PM
ceto's Avatar
ceto is an unknown quantity at this point
Default headlight problem
So the problem is that when I turn on the lights the left one doesn't work... only the high beam, I had change all the fuses n it started to work again. I took the car out again and the problem cameback but this time the fuse wasn't burn? I'm confuse on wat it could be.
Old Apr 19, 2009 | 01:14 PM
wierdguy75's Avatar
wierdguy75 has disabled reputation
Default Re: headlight problem
What kind of car? I work at a dodge dealership and sometimes the front control module has to be replaced when that happens.
Old Apr 19, 2009 | 01:15 PM
madsteez's Avatar
Ohhh Snap
madsteez madsteez madsteez madsteez madsteez madsteez madsteez madsteez madsteez madsteez madsteez
you have checked the bulb correct?
Old Apr 19, 2009 | 01:17 PM
ceto's Avatar
Yea bulb is ok. 98 Honda civic ex.
Oh yea to add to the problem that turn light doesn't work either.
Old Apr 21, 2009 | 05:04 PM
clontz_wi64's Avatar
clontz_wi64 has disabled reputation
check the housings.... they maybe burnt and melted bulb housing and thats what burnt the fuse
Old Apr 21, 2009 | 05:58 PM
Ah, so the turn signal doesn't work either.. Well, that's probably a power or ground issue going to that light. I can't remember the common way that headlights are usually wired, but from what I remember the bulbs usually either share power (in which case the ground is switched to activate the light) or share ground (then the power would be switched). SO that would be the first place I'd look; something sounds like it's affecting that entire light assembly obviously.
F4Fresh
May 13, 2008 05:39 PM
Kakarot18
Sep 2, 2006 12:31 PM
tpinoy420
Apr 13, 2004 06:20 PM
Tainty_McFshStx
Aug 25, 2003 05:24 PM
