head lamp question???? Please help.
Old 05-14-2004, 10:53 AM
Blow Me
Stillpushin's Avatar
Stillpushin is an unknown quantity at this point
Default head lamp question???? Please help.
Okay, I have an 89' 240sx with a ka24De swap. My right high beam head lamp doesn't work. I replaced it and it is the same thing. The low beam works fine. What do i need to check. (besides fuses because i already have)
Stillpushin is offline
Old 05-14-2004, 06:29 PM
Loud412's Avatar
Loud412 has disabled reputation
Default Re: head lamp question???? Please help.
All the wiring that goes to it. Check and make sure that the wires that go into the back of the bulb plug are intact and in good shape. If they arent the connector may have to be rewired. If u can figure out where the other end of the wire is you could try to ohm it out using a multimeter. But unless the other end of the wire terminates at a plug u would have to cut it to ohm it out.
Loud412 is offline
Old 05-14-2004, 09:32 PM
SSHNIPER
THATS FRESH's Avatar
THATS FRESH is on a distinguished road
it seems like you need a new headlight socket. if you dont have a multimeter to check out the wires, just go to the junkyard and scrap one.
then double check all your fuses, including your parking ones.
THATS FRESH is offline
02civicrider
05-23-2008 04:42 AM
02civicrider
02-04-2008 02:17 PM
96LsIntegra
Other ARCHIVE
01-31-2008 07:57 PM
Quick Reply: head lamp question???? Please help.
