Halfshaft Removal Help!!!
Old Oct 29, 2003 | 09:17 AM
SuMeRbOaRd's Avatar
SuMeRbOaRd is an unknown quantity at this point
Default Halfshaft Removal Help!!!
I'm having a lot of trouble getting my halfshaft out of my 93 GS-R. Can anyone give some tips or a little guide to getting it off? Thanks!
Old Oct 29, 2003 | 04:29 PM
locoboi757's Avatar
type psh
locoboi757 is an unknown quantity at this point
whats the problem?
Old Oct 29, 2003 | 06:32 PM
SHUT UP's Avatar
Smart Dumb cats
SHUT UP has a reputation beyond reputeSHUT UP has a reputation beyond reputeSHUT UP has a reputation beyond reputeSHUT UP has a reputation beyond reputeSHUT UP has a reputation beyond reputeSHUT UP has a reputation beyond reputeSHUT UP has a reputation beyond reputeSHUT UP has a reputation beyond reputeSHUT UP has a reputation beyond reputeSHUT UP has a reputation beyond reputeSHUT UP has a reputation beyond repute
thier are only 3 bolts(14mm) holding the halfshaft. Is the axel still on attached to it. If it is...it really doesnt matter. Make sure you have drained the tranny fluid because the fluid will spill out once you have taken the halfshaft off is you have tranny fluid in thier. Just grab the shaft and wiggle it loose. Not that hard to get out.
Old Oct 29, 2003 | 07:37 PM
CRXtacy's Avatar
Pro
CRXtacy is a name known to allCRXtacy is a name known to allCRXtacy is a name known to allCRXtacy is a name known to allCRXtacy is a name known to allCRXtacy is a name known to all
i duno if its good/bad but when i do it i use a big flat screwdriver or the ball joint remover/pickel fork to pop the shaft out of the tranny
Old Oct 29, 2003 | 08:05 PM
SuMeRbOaRd's Avatar
My problem is more towards the wheel... I pulled out the bolt that is at the bottom of the damper fork thing, and then the castle nut under the balljoint by the wheel, but I can't get that apart and don't know what else I need to do to get the halfshaft to come out.
Old Oct 29, 2003 | 08:46 PM
SHUT UP's Avatar
Smart Dumb cats
ok. This is how you get the joint where the castle nut was.
Get a Hammer. Put the key in the ignition and turn it just enough so that the steering wheel can move freely. you can turn the hub with your hands. turn the Hub all the way so you can see the joint from the side when laying down.
Now look at the stud where the crown nut was attached to. Now look at the control arm it is attached to. You can see a little bump right beside the joint. You have to hit that bump with a hammer. VERY VERY HARD!!!! Sometimes it is a pain in the ass but you just have to keep hitting it. Remember dont just hit the control arm. Thier is a little bump where you are suppose to hit it. hit it about 10 times on one side then turn the hib and you will see the same bump on the other side. Keep hitting it till you see it pop up loose. Then take the hub right out of the joint.
You need to hit it HARD!!!
Old Oct 29, 2003 | 08:58 PM
SuMeRbOaRd's Avatar
You are the man. Plain and simple. I'll give it a shot tomorrow. I got 2 friends comming over and hopefully I'll get this engine out by tomorrow night!
Old Oct 30, 2003 | 11:54 AM
SuMeRbOaRd's Avatar
Success!
lshonda1
Mar 7, 2009 11:25 AM
xeno
Jul 7, 2008 04:20 AM
FastPrelude420
Sep 20, 2007 04:47 AM
boostedteg
Jul 3, 2007 07:11 PM
